ActionScript Error
Need help getting the latest version of the ninja game to work? Get help here.
Triforce
Postby Rivet » 2013.07.01 (06:20)
This pops up when I press Tab to test a map, if I dismiss it, the ninja and other objects disappear and your'e left looking at the tiles.
It's worked properly in the past.
To try and fix I've deleted and redownloaded ngame and Flash Player.
Any ideas?
Postby 999_Springs » 2013.07.01 (21:00)
appears to be a (pretty disastrous) bug with the latest version. you're not alone
your image doesn't show up, use this link instead
[img]http://s22.postimg.org/qzskmacbj/NERROR.jpg[/img]
The Loneliest Number
Postby Dead_videos » 2013.07.11 (08:50)
Just in case your image fails in someway down the line here is the text
RangeError: Error #1125: The index 0 is out of range 0.
at simulation::Simulator/APP_EnablePlayer()
at editor::Editor/Tick()
at com.metanet.screens.editor::EditorApp/handleEnterFrame()
if you can't tell i too have befallen this bug.
