Bug?
Moderators: Rose, Sunset
Quarks
NUMA Profile: http://www.nmaps.net/user/bogax
Postby lenghwar4e » 2013.03.27 (14:03)
So I think I came upon a bug.My map's thumbail is wrong and it looks just like a level from metanet (from one of the default episodes), but if you load the data you will notice that the level is different.See for yourselves:
I don't know why this happened.I did have the level from metanet(kept it to play it anytime for fun), but I didn't copy that metanet's level data, I copied my own level data.
Just so you can see the difference, here is the data of my level :
And here's the data of the metanet level:
(Maybe it's not that good a level, but a bug's still a bug, right? :) )
From what I understood there were problems about thumbails in the past too, so I figured that now would be a good time to fix them.
Should I send an email the the webmaster and tell him about this?
I would appreciate if you could help me and all who had problems with those thumbails..
Thanks for your help,
lengh
P.S. Sorry if I missed any thread about this kind of problem (but I wan't able to find any).
Postby aids » 2013.03.27 (17:39)
EddyMataGallos wrote:I believe thumbnails aren't updated when you update the map data, so if you accidentally copied that metanet map data and the fixed it, the thumbnail will stay the same.
This is why. You might want to resub.
Quarks
Postby lenghwar4e » 2013.03.28 (14:37)
To make it short, I didn't update any data at the beinning because the data was good (it was my map's data,i checked it before i submitted it), but the thumbail was wrong (even if I copied the right data from the first sumbission )=>the right data with the wrong thumbail.
Anyway, I resubed it.
Thanks for your help ^
Oh and a question if I may: does nmaps.net have an option to edit posts? cause I can't find it and it's kinda annoying to triple post or quadruple post or...even worse.
"Fighting fire fliers with a blade"
Postby aids » 2013.03.28 (18:30)
lenghwar4e wrote:To make it short, I didn't update any data at the beinning because the data was good (it was my map's data,i checked it before i submitted it), but the thumbail was wrong (even if I copied the right data from the first sumbission )=>the right data with the wrong thumbail.
There is not. The best you can do is report any post you want deleted and maybe a moderator will delete the posts.
Quarks
Postby lenghwar4e » 2013.03.28 (18:38)
Ok.Thank you and have a good day :)
Postby aids » 2013.03.29 (02:12)
No, thank you for joining our community. :D
