Universezero's Map Generator
Postby Universezero » 2013.03.24 (01:27)
I have created a map generator in Python 3.3 that will randomly create a full fledged map, ready to be played (at least, most of the time it will. I take no responsibility if you happen to spawn directly over a mine). You will need to download and install Python 3.3 for it to work.
Python 3.3 Download
Here are some example maps that the program generated:
Download the attached script and run it after installing Python 3.3. It will create a file called genlvl.txt with the map data inside.
EDIT: As of 14/3/2017 I am hosting the script on my website. This may not be available in the future, but I will try keep it up as long as I can. http://leach.net.nz/docs/uznlevelgen.py
Uzi's N Level Generator V1.1.py
(11.29 KiB) Downloaded 1115 times
NUMA Profile: http://www.nmaps.net/user/RedSpartan
Postby Leonidas » 2013.06.25 (00:00)
Cool. I don't feel like messing with python, but the idea is awesome, and I am sure it works.
Click!!!
From Streetsahead
From Aidiera
Also from Aidiera
From Traveleravi
