Hi, I'm playing N for few months but I never registered on any N forum.
I've got a problem with User Levels in Nreality (n v1.4 has the same problem)
I'm downloading maps using NADS and from mappacks. I've got 1761 levels in userlevels.txt but N shows me 1430. Is there a way to fix it?
Below I'm attaching my userlevels.txt file
User levels don't show
- Almost as Bad as One
- Attachments
- userlevels.txt
- (2.75 MiB) Downloaded 1168 times
Hello there. The reason you userlevels don't so is because there are "&" in the textfile. N uses the & as a prefix for the levels (&userdata=) and when it shows up in mapdata such as titles and authors andwhat, it makes N think that it's another start of the userlevels.txt file, and doesn't register with N. The easiest way to fix this would be to find and replace all & with 'and' (+ won't show up) except for the first one.
Thanks for asking. :3
Everything is working after replacing, thank you very much :D
