The Mappack Catalog
Moderator: zoasBE
Postby zoasBE » 2011.09.03 (03:47)
The Mappack Catalog
(Last Updated: 5 August 2015)
534 PACKS
The list was first put together in the old forum by apg, and was later updated by Skyline due to apg becoming inactive in the community. Then 29403 was in charge, but he bequeathed it to squibbles. squibbles forgot about it, so Aidiera took matters in to his own hands. (incluye deserves credit for doing some nifty coding to fix the dates. :3) zoasBE has now taken over for Aidiera.
This thread is an attempt to list every single level pack ever made. It makes browsing through the huge amount of level packs a lot more convenient. Incomplete/aborted packs have GREEN names, collections (packs comprised from previously released works, or maps now available on NUMA) have BLUE names, and packs with multiple authors have PURPLE names. The number of maps, release date, and authors/compilers of the packs are also mentioned. (Terribly incomplete packs [i.e. packs with less than 3 maps] aren't listed.) Post here to have any corrections made or if you would like another pack pack added. I will be updating this at least once a month.
Sadly the old forums have been taken down. We are in the process of collecting as many of the old mappacks as we can. Head over to the collection thread and see if you can help us. The recovered mappacks are being uploaded to sidke's PACKS so you can quickly find them on here. All of these mappacks will point to the same thread, which I've set up as a way to talk about the old packs.
March 2013: The old forums are back up! I'll try my best to update the Catalog with new links to the old forum packs, but I'm going to keep the PACKS links too, because why not?
how to play the map packs
  1. Open the attached levelpack and copy it to clipboard using Ctrl/Command + A and Ctrl/Command + C.
  2. Paste the pack to your userlevels.txt with Ctrl/Command + V.
    or
    Rename the previous userlevels.txt (to e.g. userlevels2.txt), and create another text file and name it userlevels.txt. Then paste the pack to that file.
    The latter way is convenient when you have lots of map packs and want to keep them in order. Also, your userlevels.txt won't get stuffed up causing the loading time to become painfully slow.
  3. Check that &userdata= is listed before before the levels. There can be text above it though.
  4. Open the application and click on "user levels" in the main menu. Then, select the map you want to play and start playing!
Pack Name - Cumulative Map Count - First Release Date - Author(s) - Thread -- Link to PACKS
[/list]
just as friends as enemies
even fewer friends
Postby aids » 2011.09.04 (00:46)
reached character limit on first post, moving to this one
original text:
lukesv wrote:I'm glad that Aidiera is taking this over, cause the last one never got updated.
Mappacks, cont.
2006
UNKNOWN
I have no clue when any of these were released so if you do then post below.
Postby zoasBE » 2011.09.05 (02:14)
<3
even fewer friends
Postby Sunset » 2011.09.05 (12:26)
WOO
Postby mathy » 2011.11.15 (18:26)
Include COMPILATIONS!
Postby Donfuy » 2011.11.23 (14:12)
Oh my god this is still up to date? Very surprised. Good job and also this is like pokemon im gonna play'em all cus that's like - my dream
Postby otters~1 » 2011.11.23 (22:48)
Donfuy wrote:Oh my god this is still up to date? Very surprised. Good job and also this is like pokemon im gonna play'em all cus that's like - my dream
TELMO IS IN A TUNA
Postby Donfuy » 2011.11.25 (16:44)
TELMO IS IN A TUNA
man we should make a mappack together called tuna
Postby otters~1 » 2011.11.26 (01:40)
TELMO IS IN A TUNA
sure
how did that go by the way
Postby Donfuy » 2011.11.26 (01:54)
boustrophedon wrote: sure
It feels fucking amazing to be on stage. One of the best feelings ever, actually.
Postby zoasBE » 2011.12.19 (16:37)
hi friend,
the link of #Brbfest pack is broken, please fix
and you can include on list the "20 Variant Mappack Beta" by paradox ( http://forums.droni.es/viewtopic.php?f=39&t=8984 )
thanks, I hope you're fine!
THANKS!!!
even fewer friends
Postby 29403 » 2012.02.18 (23:00)
Oh man, that Metanet Bitesized entry is soo out of date :D
Donator
Donator
NUMA Profile: http://nmaps.net/user/DW40
Postby DW40 » 2012.02.25 (22:45)
Thanks for keeping this list together. Here's one to add -
[*]proliferation - 176 - 15 Feb 2012 - DW40 - Show Topic
Postby aids » 2012.02.26 (03:03)
BanjoDave wrote:Thanks for keeping this list together. Here's one to add -
You win an award for the coolest author ever. Thanks DW! That was very helpful. <3
Postby zoasBE » 2012.02.27 (03:26)
Aidiera, I need some help.
I can find Vehemence and Vehemence 3 (that's easy no? :P) but where's Vehemence 2??? Shows me plizx!
You can explain me?
even fewer friends
Postby EddyMataGallos » 2012.02.29 (20:39)
Postby zoasBE » 2012.03.01 (00:12)
thanks you so much!
Aidiera, please you can update the list with this link, i think is an important mappack.
Thanks you two!
even fewer friends
Postby zoasBE » 2012.07.26 (18:42)
Hi Aidiera!,
I have post here some things that might be interesting.
First of all, ask you to please you modify the status of my mappack (CORaN) in this Thread, this is not a mappack group or by multiple authors. It has only been done for me. Of course there collab maps (as in many other packages of authors) or any another remix, but there is not even a single guest map or this package has been proposed some other author. It has been hard work only for me. Also if you please correct the 'spoiler' thing mistake. Thanks.
On the other hand several things.
On Eight Maps from Yahoozy there are 8 maps not 3 as you've indicated here.
Should update the list with Jump! from Paradox although this is not completely done.
Also NReality graphic maps from NPLUS.
More stuff, It would be interesting a thread for your userlevel'd package is hidden in your signature. I do not think many people know this, and it would be interesting that everyone could access it. A thread would be perfect, and put it in the catalog. Do you think?
Two other very interesting things that would be as follows, first, to catalog or add a new thread that those maps were obtained from the Holiday Contesque of Metanet. If you tell me where to find them, I can make the thread and you add to the catalog. And second, and finally, link and add to catalog the package is finally finished Bitesized N also could relocate the thread to this subforum?
I hope these ideas will serve better to have everything organized and handy. I hope you can work and put all this in order.
Thank you very much again, and it's great work you do in the community of MapPacks.
A greeting.
even fewer friends
Postby aids » 2012.07.27 (07:12)
zoasBE wrote:Hi Aidiera!,
Well, I felt that there were enough collabs to warrant a 'multiple authors' color, but it's your pack so I'll do as you please.
zoasBE wrote: On the other hand several things.
Fixed the hooz thing, thanks. Added Jump! and added graphic maps (and fixed the userdata).
zoasBE wrote: More stuff, It would be interesting a thread for your userlevel'd package is hidden in your signature. I do not think many people know this, and it would be interesting that everyone could access it. A thread would be perfect, and put it in the catalog. Do you think?
Nope, not yet. I have a special purpose for it, and pretty soon you're all see what it is.
zoasBE wrote: Two other very interesting things that would be as follows, first, to catalog or add a new thread that those maps were obtained from the Holiday Contesque of Metanet. If you tell me where to find them, I can make the thread and you add to the catalog. And second, and finally, link and add to catalog the package is finally finished Bitesized N also could relocate the thread to this subforum?
I have nothing to do with finding that data, but if you do and make a thread, I'll add it. And I can't move threads, but I'll update the catalog accordingly.
zoasBE wrote: I hope these ideas will serve better to have everything organized and handy. I hope you can work and put all this in order.
A greeting.
Awww, you're welcome. :)
Postby mathy » 2012.08.09 (15:02)
Add Extension!
Postby aids » 2012.08.09 (17:08)
mathy wrote:Add Extension!
Done and done. :D
NUMA Profile: http://nmaps.net/user/runningninja
Location: The indefinite integral of the derivative of x
Postby runningninja » 2012.08.14 (07:08)
play my new mappack signature
thanks weird eyed girl
nvm, you already did it -_-
although signature has 27 maps in it (a-z + 1 bonus), not 25.
Much appreciation Aidera!
Postby zoasBE » 2012.09.01 (01:59)
Thanks Aidiera for having added Astro Chimp, I'm happy this is out at least.. :P
Can you add also, flamenco by bio, please. ;)
See ya!!
even fewer friends
Postby aids » 2012.09.01 (02:57)
zoasBE wrote:Thanks Aidiera for having added Astro Chimp, I'm happy this is out at least.. :P
See ya!!
flamenco does not qualify as a mappack and Bio should sit in the corner and think about what he's done. :/
Postby zoasBE » 2012.09.01 (03:12)
See ya!!
Oh that's ok then, thanks and sorry ;)
even fewer friends
