I need help
Moderators: Rose, Sunset
The Loneliest Number
Postby Daniel19496 » 2008.11.21 (01:57)
Okay, I'm so very new to this.
People put a "Dema Data" in comments to maps on NUMA website, what is that? Is it a replay of them playing it?
Thanks
Daniel
Postby Nexx » 2008.11.21 (02:01)
Yes, it's their replay, just as you expected.
There are 2 ways you can watch a demo.
(1) Userlevels: Go to the userlevels section in N, and you'll see a white box in the lower left side. Copy and paste your map data from NUMA in there, and then copy the demo data and paste it at the very end of the map data. Then click "watch replay".
(2) Editor: Go to the editor. Replace all text in the level data box with your map data (gotten either from NUMA or your own saved data - both will work). Click outside the level data box and press 'L' to load the map. Then replace all text in the demo data box with their demo. Click outside the demo data box and press '3' to tell the editor to pay attention to the demo data box and then 'Q' to load that data. Then press 'P' and the demo will play. You'll notice the movement controls will not respond while playing a demo. And by the way, all the controls I mentioned are listed in the bottom left of the editor main menu with brief explanations.
Postby Rikaninja » 2008.11.24 (07:19)
That's all the imformation you need. And yes, when asking for help always ask on Metanet.
