enemies
i hav seen some ppl make enemy drones stay still and i would like 2 know how they did it.
and here is a random lvl i made
- Walking on Broken Glass
- NUMA Profile: http://nmaps.net/user/hoohah2x2sday
if i understand what ur asking, then u want to no how to make a drone stay in the same spot as u put in in the eidtor right?
well, place the drone where u want it, and then immediately go to the textbox (level data). The drone should be the last group of text in the box. Simply add "nan" to the end of the code, and then load the level again. when u play it, the drone shoud stay still.
I hope this helped =]
- Wizard Dentist
An alternative method is to place locked doors around the drone you want immobilised.
Like so:
But Hoohah2x2sday's method is probably the best to use.
Like so:
- MBTI Type: ESFP
That works, but it's not really aesthetically pleasing.SkyPanda wrote:An alternative method is to place locked doors around the drone you want immobilised.
Like so:
And make sure you put it in the right place, you don't wanna make a ghost drone..
[/spoiler]
[/spoiler]-
- Wizard Dentist
Personally, I think it looks fine, the only problem with that method is that it uses a large amount of objects, which is why code-editing is probably a better method.TribulatioN wrote:but it's not really aesthetically pleasing.
- Mr. Glass
You really think it looks ok? Hmm.SkyPanda wrote:Personally, I think it looks fine, the only problem with that method is that it uses a large amount of objects, which is why code-editing is probably a better method.TribulatioN wrote:but it's not really aesthetically pleasing.
Regardless, the use of doors to keep a drone stationary is entirely redundant when you can just edit the code in the same amount of time. there's no need for at all unless you don't know the code edit.
- Wizard Dentist
Yep. Like a little drone-in-a-box :)atob wrote:You really think it looks ok? Hmm.
This is a code for a chingun drone:
Change the 3 to a 9. This will make the drone still.
But of course the numbers may be different but there will be the same amount of number so you have to change the 3rd number to a 9. There are other ways to do this.
6^588,516,3,0,2,2Code: Select all
6^588,516,9,0,2,2
- MBTI Type: ESFJ
basically just muck up the 3rd number so it becomes a NaN ... thats what makes it still
[align=center]
u dont even have to worry about changing numbers, adding anything to the end of the code will nan it anyway. i prefer to just type nan =P
