Problem submitting map.
- Semimember
- Oops Pow Surprise
- On the Psychic Highway
Means you have too much tiledata. Make sure it looks right in the editor and if it does try removing the last symbol before the |
- Semimember
Try posting it here, either in quote tags or attached as a .txt
I know LV is good at fixing dodgy data, somebody should be able to look at it for you.
- Oops Pow Surprise
no not in a quote tag. bad idea.entwilight wrote:Try posting it here, either in quote tags or attached as a .txt
Either myself or LV can edit it out correctly. We're both pretty equally well-versed in reading code.
My apologies, you're right. Fancy new forums.大見解 wrote:no not in a quote tag. bad idea.entwilight wrote:Try posting it here, either in quote tags or attached as a .txt
- Semimember
Try that. I think you were missing some 0's at the end.
- Semimember
