The BKPB58 Columns
Moderator: zoasBE
Unlucky
Postby BKPB58 » 2010.07.30 (08:12)
15-19:Kontakt Is Released
This Will Be The List Of My Maps In Episodic Order
1st mappack:00 - 09
2nd mappack:10 - 14
3rd mappack:15 - 19:Kontact
Hope you enjoy them!
Criticism And Comments Are Allowed
15 - 19.Kontakt.txt
2nd half of the episodes in my 2nd column
(63.33 KiB) Downloaded 401 times
10 - 14.txt
1st Half Of The Episodes In My 2nd Column
(57.19 KiB) Downloaded 421 times
1st Column Highlights.txt
(39.79 KiB) Downloaded 402 times
"What's The Use Of Prolonging the inevitable?" ~Squeeky,Toy Story 2
Next Mappack Under Construction
Postby ENT474 » 2010.07.30 (16:33)
Some advice:
You should put all your first 10 episodes for people to evaluate.
You shouldn't place half-snap gold or mines.
The tiles seem placed randomly, without thought. The thumbnails need to be good in order for people to click on it and play your map.
Don't put objects on other objects. It's a trap that can easily be avoided after running into it once. Most people of the community thinks it's bad.
Make your maps more dangerous or easier. It looks a bit like you can't make up your mind whether you want it hard or easy.
Some maps seem to open or closed. Adjust to your likening.
I changed the objects on 00-4, it seems a bit better.
Unlucky
Postby BKPB58 » 2010.08.10 (06:50)
2nd Mappack Released :D
Unlucky
Postby BKPB58 » 2010.09.07 (06:46)
Sorry For Double Posting for those who are going to this thread, I am recently making new maps but I won't be posting any maps at NUMA 'till some time after the next mappack is released.
