Nreality - replays help
- Almost as Bad as One
Hey guys!
Im having trouble with viewing my own replays. In the highscores area, when I click on a replay it loads the level but the ninja stands still. Is it a common issue? And is there any solution for this?
Thanks in advance!
Durfi
Thanks in advance!
Durfi
Are you sure that you're clicking the time or the View Replay button rather than the map?
Hello!
I click on the Map number in the "Personal bests" section top left. I've made a screenshot, cause I guess its not the way it should look like:
There are no personal bests at all : S
- MBTI Type: ESTP
From the screenshot, Most likely your problem is:
1) You need to login (main menu --> configure)
2) You lost your .sol and should check and see if you have it. Link!
It may be another problem (or problems), but those are the two most likely.
