64bit Ubuntu and N
Almost as Bad as One
Postby anubis » 2010.04.24 (21:48)
hey so im trying to install N on the 64bit version of Ubuntu (9.10) but whenever i try to run it, nothing happens
running from the terminal has this output
~/Downloads/n_v1linux$ ./n_v14
./n_v14: error while loading shared libraries: libgtk-1.2.so.0: cannot open shared object file: No such file or directory
i looked around the forums and found that i needed to install libgtk1.2, but when i try to do that i get
sudo aptitude install libgtk1.2
Reading package lists... Done
Building dependency tree
Reading state information... Done
Reading extended state information
Initializing package states... Done
No candidate version found for libgtk1.2
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0B of archives. After unpacking 0B will be used.
Writing extended state information... Done
so now what do i do? thanks for any help.
Postby Vyacheslav » 2010.04.24 (22:51)
Try
sudo apt-get install --reinstall libgtk1.2-common
Postby anubis » 2010.04.25 (02:25)
says it can't find the package...
E: Couldn't find package libgtk1.2-common
Postby Vyacheslav » 2010.04.25 (02:32)
Update your repositories? I'm not that experienced with Linux.
Postby t̷s͢uk̕a͡t͜ư » 2010.04.26 (03:12)
While GTK (and Ubuntu) have updated over the years, N has not. libgtk1.2 is not available in Ubuntu repo's because it's horrendously outdated.
You could try to find libgtk1.2 somewhere, and then seek out other missing pieces as they come... or you could just run the Windows version of the game through Wine, which is what I've been doing for years now.
