How much time do you spend on maps?
Postby Radium » 2008.10.29 (14:40)
I generally spend about and hour and a half. 30 mins for tiles, 45 mins for object placement, 15 mins for playtesting.
The longest time I have ever spent is about 3.5 hours.
The shortest time I've spent is about 15 mins.
Postby a happy song » 2008.10.29 (14:44)
Anywhere from 10 minutes to a couple of weeks (from concept to product).
Postby 29403 » 2008.10.29 (15:18)
I never spend more than 20 minutes. More minutes won't fit my busy plan. Besides I get bored after 20 minutes.
Postby MattKestrel » 2008.10.29 (17:27)
Usually, anywhere between 2 and 3 hours. I have an unfortunate amount of time on my hands :(
Postby 29403 » 2008.10.29 (17:54)
GTM wrote:Usually, anywhere between 2 and 3 hours. I have an unfortunate amount of time on my hands :(
Lucky you.
Postby Pheidippides » 2008.10.29 (18:01)
Same as atob, although I rarely do ten-minute maps or maps that take several weeks. The average is usually a few hours over the course of 1-3 days.
Postby Condog » 2008.10.29 (20:14)
Usually a few hours, butmost of the time I keep fiddling with little details and it turns into days. Ten I get annoyed and submit a crap map. :P
Postby 29403 » 2008.10.29 (21:35)
Condog wrote:Usually a few hours, butmost of the time I keep fiddling with little details and it turns into days. Ten I get annoyed and submit a crap map. :P
Days? :O
MBTI Type: ESFJ
Postby jackass » 2008.10.29 (21:38)
Well .. I now normall do 2-3 hours or sometimes a bit less , but only now i used to make bad maps in like 10 - 20 mins
[align=center]Image
Postby Nexx » 2008.10.29 (22:17)
Generally 1 - 2 hours. That's why I don't map as much as I'd like to.
Postby Kablizzy » 2008.10.30 (00:33)
atob wrote:Anywhere from 10 minutes to a couple of weeks (from concept to product).
My quickest map was a 60-second map I did a while ago, and I've gone from there all the way up to three years working on the same map or versions thereof.
Postby Radium » 2008.10.30 (01:36)
Seriously, you're spitting out 1-2 a day. Do you go to school?
Postby George » 2008.10.30 (01:55)
The majority of my maps have taken around twenty minutes to an hour to make, sometimes over a couple of days. It really depends if my mind is bleeding creativity or not, which it isn't, most of the time.
My DDAs took me a couple of hours each to make. They're the longest times I've ever spent on my maps.
Postby notsteve » 2008.10.30 (02:23)
i like to spend less than half an hour on a map
usually some of my lengthly creations take much longer
Wizard Dentist
Postby SkyPanda » 2008.10.30 (13:06)
An hour or so, but its never a single map, its a map that changes into other maps, and eventually I stop changing the map and call it finished.
Postby Evil_Sire » 2008.10.30 (13:36)
I have half term. I suspect he does too
Postby TheRealOne » 2008.10.30 (14:33)
since i mostly make simple challenges it takes only a few minutes to put the map together, but it takes hours of time playing around with random objects and tiles to see what kind of cool tricks you can do with them. and then it takes a few more hours to get the distances just right to push the limits of those tricks. then i usually have a few people play test the map. so from beginning to end it could take anywhere from 1-5hours of messing around.
Postby Eiturlyf » 2008.10.30 (15:43)
Fastest - 3-4 minutes. Slowest - 50 minutes.
Never ever goes beyond one hour.
Postby 29403 » 2008.10.30 (17:24)
Eiturlyf wrote:Fastest - 3-4 minutes. Slowest - 50 minutes.
Me steals Eiturlyf's post.
It's true though!
Postby MattKestrel » 2008.10.31 (17:27)
Yeah, atm its half term, so I usually have enough time to make two maps in a day. Just one per day on schooldays; I probably overestimated the time it took me to make maps anyway, 2 hours is more likely the total.
Postby twentythree » 2008.10.31 (17:52)
I spend about 5 minutes on my maps.
I work pretty hard on it for about a minute, then I get kinda lazy and sloppy and they never turn out real good.
23!!!!!
Postby blackson » 2008.11.01 (02:38)
However long it takes.
Postby OneSevenNine » 2008.11.01 (05:27)
Usually an hour, but I try not to go over an hour and a half or so because by then I've tweaked the map so much it playing feels like wearing badly-patched pants (so to speak).
:loud music:
Postby Geti » 2008.11.01 (08:16)
depends on the complexity. a short, minimal action, maybe 20-30 min. a huge complex bitch of a map? maybe 4 hours tops, if i cant sleep.
as blackson said: as long as it takes.
God knows if i'm back.
Antagonistic Fencesitter
Postby KinGAleX » 2008.11.02 (07:18)
Between about half an hour and an hour and a half. I've had maps half-made that have sat there for months, but I don't think that really counts. Actually working on the map doesn't take too long.
* Sig provided by Steve.
More relevant images!
