Episode 5 Level 3 HELP
- MBTI Type: ESFP
This will help! :)
Hi.
Alright, I will go step by step because this level is kinda complicated for new-starters-to-N.
First of all, follow the black line, then wait there. (There is a zap drone right in front of you, heading towards you, but it won't hurt you, just wait there 'till it goes away)
Now, continue with the black line, assuming that the drone heading towards you is gone. You should be quick when getting the switch, hurry.(It's about the get between the thwumps in the pic.) Okay, when you get the switch, get out of there fast as you can. (Follow the red line)
Okay, this is where things kinda start to get complex. You did follow the red line, there is a 3x3 empty area where 3 gold pieces are placed. And you see the drone coming towards you? Yeah, you should jump and get away from that drone before it kills you. A'ight. You managed to get away from the drone, then, whereever you are, follow the red line to get the other switch to unlock the doors and the switch to open the door to next level. Whilst you are doing these, watch out for the thwump and the drone(s), and be quick. After you get the switch for the door, follow the blue line, get to the place were the blue line ends. If you can manage to do this step without dying, you survived the most complicated part of this tutorial.
After all these, you know what you should do. Head to the exit door, and be quick, you should avoid the thwump. (yeah I know)
Bravo!
Edit: The link amlt gave is for Episode 5 Level 4, so you might want to use the help I provided. ;D Oh, also, if you have any question or you cannot pass the level, I / We will help you in a more descriptive and easy way, so don't worry. ;D
Edit two: Better tutorial. D:
Bravo!
Tunco pretty much nailed it. Do that.
