I don't know if this could be used for any in-game highscore, but I imagine it'd be cool in races and whatnot.
Map 186497 if anyone's interested.
Rediculous Propulsion
- MBTI Type: ESFP
Hi.
Thats what happens with a Thwump squeeze to a BTWJ 1 frame after.
- MBTI Type: ESFP
I'm guessing you mean both are happening sort of at the same time. I only pressed jump the once to get that massive push.TheRealOne wrote:Thats what happens with a Thwump squeeze to a BTWJ 1 frame after.
Hi.
Well I suppose you could count them as happening at the same time depending on when you pushed jump, but thwump squeezes don't require a jump for propulsion. So only one jump would be required. when you are squeezed like that though you can do several successive BTWJs in a row on the same thwump and get even more propulsion. This is done in my new DDEDDA at the start I do two btwjs during a ts giving me a lot of speed.amomentlikethis wrote:I'm guessing you mean both are happening sort of at the same time. I only pressed jump the once to get that massive push.TheRealOne wrote:Thats what happens with a Thwump squeeze to a BTWJ 1 frame after.
