Are user levels on NReality not currently working?
- Almost as Bad as One
Hello; I am simply wondering if there is a server issue right now, because I'm not able to see any user levels when I load NReality. Early today, it seemed to be working. However; now, it is not. Is there a reason for this? Also, is there a way to check on the current status of the server to know if it is down or under maintenance?
It's working for me.
You sure it's not working?
Because it was fixed several hours later after servers are down.
I launch NReality, click "user levels", and then I am presented with a blank gray space with one level named "0". Then, when I click "load numa map", it loads a map named "Unreality". That seems to be the only user map I have access to.. What am I doing wrong?Tunco123 wrote:It's working for me.
Edit: I am operating under the assumption that NReality pulls user levels from NUMA.. is that correct? Also, here's a picture of my "user levels" screen..
Okay, it's not down, you just don't know how to use it.
Go to Numa, if you don't know, you seem to be new to this, and click any map on the hot maps screen.
Ex: http://nmaps.net/181525
You see 181525? That's the Map ID. If you want to play that level on NReality, just type the Map ID to the empty box-where it says 111791, instead type the map ID. Click to "Load Numa Map" And you're done. Click on the level to play it, if any highscore has made on the level, you can see the highscore board, make sure you get a Numa account, and a NReality one, (which you need to have for having a Numa account).
Welcome to the community, bro. Make sure you read FAQ and the one on Numa. 1st one is more detailed and updated, read that one first.
Check out Mapping theories and stuff.
- Bacardi
- NUMA Profile: http://nmaps.net/jinxed_07
easy problem. Paste your userlevels into your Nreality folder xD too simple...lukeman3000 wrote:I launch NReality, click "user levels", and then I am presented with a blank gray space with one level named "0". Then, when I click "load numa map", it loads a map named "Unreality". That seems to be the only user map I have access to.. What am I doing wrong?Tunco123 wrote:It's working for me.
