Metanet Bitesized :: LEVELS FINISHED! :D Playtesters needed!
Moderator: zoasBE
The Future of Metanet Bitesized
1 Remove backgrounds
0
No votes
2 Center all levels
3
20%
3 Remove backgrounds and center all levels
6
40%
4 None of the above
1
7%
5 Capital Letters as Titles
2
13%
6 lower case letters as titles
3
20%
Total votes: 15
Postby 29403 » 2009.08.18 (15:05)
Metanet Bitesized! Image
or MetaBite. =)
It's dangerous to go alone... take this.
NEWS
Updated 20-01-2011
Great stuff! Another column's done and we've got less than a hundred to go. Keep going, and we can get this finished!
Updated 29-12-2011
Suggested Improvements
I've been thinking of a few changes to improve this thing.
- Remove all the 'backgrounds' (tile decorations outside the level) that weren't originally in the game, to keep this thing constant {but a bit boring =( }
- Center all the levels (this will look neater but really, really fiddly to do.)
Capital Letters
Paradox-Dragon very kindly fixed all typos and capitalised all the level names, so thanks again! However, I was thinking of keeping with the style of N and keeping the titles in lower case.
Voting
I've made a poll for these changes: you're allowed two votes, one vote goes to 1, 2, 3 or 4; and the other vote goes to 5 or 6.
IMPORTANT
Naming Levels
For the sake of organisation, post your maps in this format: $<Map Number> Mini <Original Map Name>#<Your Username>#Metanet Bitesized#<Level Data>#. Thanks.
Check Before you Make!
Check the 'To-Do Pile' before starting a level, unless you would like to improve it. This will prevent duplicates and time wasting, however if one of the levels you have duplicated is mine, yours is in and mine is out.
Quality Control
Check the quality control for levels that will need to be remade (they will all be levels that were made by me, unless you're not happy with one of yours.) Tell me if this is the case, and I'll edit it onto here. If you want to remake someone else's level that isn't mine, you'll need permission from that person. Send them a PM and forward the reply to me, and if they're OK with it, you can remake the level.
PROGRESS
The pack has 500 levels. The project is 100% complete.
Quality Control
- Perhaps 33-0 since it's too hard.
Helpers
  1. Ad
  2. Alphanier
  3. AMLT
  4. bhz
  5. bugz
  6. DW40
  7. exuberance -
  8. Fallen
  9. Hypnotizer
  10. jackass
  11. Kimmie
  12. kkstrong0
  13. Limer
  14. motocrosser
  15. NachoCheese
  16. N_Master3_0
  17. notkitt
  18. numa_ninja
  19. OneSevenNine
  20. Paradox-Dragon
  21. pepi321
  22. Pheidippides
  23. Rule
  24. sc979
  25. Scrivener
  26. Shark
  27. TheWigginator
  28. trance
  29. Tunco123
  30. uNcoNditioNal
  31. Usaswim
  32. walrus_of_death
  33. whykickamoocow
  34. 15_
  35. 29403
[/spoiler]
Let's get this thing finished.
userlevels.txt
475 LEVELS OF MININESS.
(659.35 KiB) Downloaded 2589 times
Postby amomentlikethis » 2009.08.20 (22:12)
Hi.
MBTI Type: ESTJ
Postby Ad » 2009.08.22 (18:08)
80-0, 80-1 and 80-3 have been mini'd.
I haven't centred the first two, but I'll do so if you want.
metabite.txt
(3.44 KiB) Downloaded 2462 times
Postby 29403 » 2009.08.22 (18:51)
They are all brilliant! It doesn't matter if some of them aren't centered, some of the other maps aren't. Updating!
Postby OneSevenNine » 2009.08.22 (22:51)
Sign me up for episode 50.
:loud music:
Postby 29403 » 2009.08.22 (22:55)
OK! I'll be avoiding episode 50.
Postby OneSevenNine » 2009.08.23 (01:40)
I was on a roll, so I finished up the ones still missing from episode 51 as well.
This was fun, I'll do it again sometime.
Episode 50, 51-0, 51-1, 51-3, 51-4.txt
(12.03 KiB) Downloaded 2434 times
:loud music:
Postby 29403 » 2009.08.23 (10:36)
Thanks. They are catchy once you get into doing them!
Postby Tunco » 2009.08.23 (10:58)
I can make 13-1, 13-2, 13-3, 13-4.
Postby Tunco » 2009.08.23 (12:08)
Done.
MetaBite (13-1,13-2,13-3,13-4).txt
MetaBite Levels 13-1, 13-2, 13-3, 13-4.
(4.69 KiB) Downloaded 2399 times
Postby 29403 » 2009.08.23 (12:24)
Fantastic job. I've updated the list but I won't update the pack till it's past the 300 mark. It gets a bit tiring updating the pack every few hours!
Thank you Tunco!
Postby numa_ninja » 2009.08.25 (07:37)
OHBOYOHBOYOHBOYOHBOY.
Postby 29403 » 2009.08.25 (15:04)
numa_ninja wrote:OHBOYOHBOYOHBOYOHBOY.
Are you planning on finishing the 30s column?
Commodus
Postby Rule » 2009.08.29 (11:32)
I did an attempt on doing a mini 14-4 and 16-1.
Metabite - 14-4 16-1.txt
(2.12 KiB) Downloaded 2383 times
Postby 29403 » 2009.08.29 (12:40)
Thanks.
Also, why do you have only 1 post?
Commodus
Postby Rule » 2009.08.29 (13:29)
I asked LV to reset it. Because people were moaning about me spamming just to raise my post count.
Sometimes it was but meh, I had to prove I wouldn't spam anymore, and this was the way.
EDIT: I did Episode 15 as well. 0/1/2 were pretty damn hard to do, so they didn't turned out perfect, so only use them when you want to. :)
3/4 were easy ones.
EDIT: Damn, 2 is kinda errored, lemme fix that.
Metabite - Episode 15.txt
Fixed 15-2 2 times.
(6.22 KiB) Downloaded 2379 times
Postby 29403 » 2009.08.29 (22:24)
All of them are good.
Next update will be at 325 maps.
Postby Rhekatou » 2009.08.29 (23:20)
This is WICKED.
Postby 29403 » 2009.08.29 (23:44)
Thanks.
Want to help?
Commodus
Postby Rule » 2009.08.30 (09:27)
16-2 ;) This one went great. O, and if you don't like getting just one map in a post, I'll do more maps in one post next time.
It's just that I like to do 1 episode per post, or all unfinished maps in an episode, I hope you don't mind ;)
As I said: 16-2
Metabite - 16-2.txt
Episode 16 Level 2 ((Works))
(1.14 KiB) Downloaded 2457 times
Postby 29403 » 2009.08.30 (12:48)
Stop RIGHT THERE, Rule. I've finished the whole 10s column. However, your 16-2 is in the pack.
Commodus
Postby Rule » 2009.08.30 (13:32)
As requested to stop on the 10s column, I turned my head to the 30s column.
So here are 34-3 and 34-4. ;)
P.S.: I'm sorry for the fake door on 34-3 but there wasn't enough room for another door at the bottom.
You'll get past that point anyways.
EDIT: Respect for you on doing the 10s column, must have been a lot of work.
Metabite - 34-3 ... 34-4.txt
Level 34-3/34-4
(2.89 KiB) Downloaded 2367 times
Postby 29403 » 2009.09.01 (23:14)
Alright, next update at 350 maps. Just so you know, I'll be working on the 70s and 90s, but will have no internet connection, so I can't update.
Postby Tunco » 2009.09.02 (08:38)
Not now but, I will help you with 70s column sometime.
Commodus
Postby Rule » 2009.09.02 (20:32)
Yet another small contribution to this.
Metabite - 52-3.txt
Level 52-3, hooray!!
(1.46 KiB) Downloaded 2321 times
