The idea behind all these levels is that the main base your ninja is in is
becomming infected by a plague of corruption and all the tileset in the levels changes
to sharp and scary. I thought of this idea because i wanted the levels to get harder
and harder and start off with easy tileset and make it get harder as well as the enemies
and gold placement ofc.
There are 10 exciting new levels containing cool tilesets and becomming increasingly dangerous as you go through them
Try it and see if you can complete them
If your an expert try Hard Mode which is getting all the gold :)
Corruption
Moderator: zoasBE
- Almost as Bad as One
- Attachments
- Corruption.txt
- 9 action maps and the last one is a race map
- (18.32 KiB) Downloaded 186 times
- Member
- NUMA Profile: http://nmaps.net/user/I_am_unknown
you know, you're doing it wrong. check out other mappack files and you'll see what i mean
my first mappack is out!
I_AM_UNKNOWN
p.s:i made the entire picture. the dragon from coreldraw and the rest from adobe photoshop
I_AM_UNKNOWN
Thanks alot for your amazing help mate with MSN ect, i know can do it fine and its all working properly
