What should I do next?
Postby njitsu » 2009.07.31 (01:31)
It's supposed to be a race map.
mapping since '06
-+- njitsu -+-
Postby Yoshimo » 2009.07.31 (01:40)
First, put the data in map tags. Second, add speed to the start. In a start like that, you need some intitial speed.
Postby njitsu » 2009.07.31 (02:40)
Hmm, I'll try lowering him into the ground a bit.
mapping since '06
-+- njitsu -+-
Postby chume14 » 2009.07.31 (16:15)
Its way too hard even for a normal map let alone a race at its current length. Unless you can complete in on most attempts (and be honest with yourself on that) you need to sort the difficulty of what you've already done before continuing.
NUMA Profile: http://nmaps.net/user/Guiseppi
Postby Adoniseppi » 2009.07.31 (16:22)
The beginning is too difficult. Way too difficult. I think adding a big jump off the platform at the right would be cool, and then having some more stuff at the bottom. I also don't think it flows well with the launch pad at the top, but maybe I was just doing it wrong.
Postby njitsu » 2009.08.08 (23:16)
glümp wrote:The beginning is too difficult. Way too difficult. I think adding a big jump off the platform at the right would be cool, and then having some more stuff at the bottom. I also don't think it flows well with the launch pad at the top, but maybe I was just doing it wrong.
Are you kidding? It's easy as hell. Just chimney. I can do it every time. Here's a demo (for the newer version of the map I posted below) It's even possible to do it and only get one of the two gold pieces covering that mine, but that's really hard :p
I changed the third segment to something actually fitting.
mapping since '06
-+- njitsu -+-
