Project Euler
Anyone else here do these? I've tried a few, mostly the ones I think I can implement quickly. Here's (spoilers!) my take on problem 72, in lua.
Meanwhile, my solution (in Python) for #72 before looking at yours:
http://pastebin.ca/1435100
On the plus side, it's a great way to learn the math library.Tsukatu wrote:Goddamnit, scythe. Now I have to do all of these. Thanks a friggin' ton. Ugh.
Do you need to sort the factors? It seems like they'd be in order simply because of the way you sorted them.Meanwhile, my solution (in Python) for #72 before looking at yours:
Oh. Yeah, probably not. Just making sure it looked clean during debugging.scythe wrote:Do you need to sort the factors? It seems like they'd be in order simply because of the way you sorted them.Meanwhile, my solution (in Python) for #72 before looking at yours:
I mean, I also didn't need all the wacky length checking for num and den because I knew I'd be feeding it numbers between zero and one only, but meh.
Yeah, I just got nerd sniped. <_<
