NUMA tags not working for new domain.
Moderators: Rose, Sunset
Postby MattKestrel » 2009.05.09 (20:47)
I just it was worth pointing out: NUMA tags added from since the domain change don't work unless the www. bit is removed. Is there a solution planned in the works?
Postby Rhekatou » 2009.05.13 (02:48)
GTM wrote:I just it was worth pointing out: NUMA tags added from since the domain change don't work unless the www. bit is removed. Is there a solution planned in the works?
haha, i wish i'd read this!
i just reported that problem on ps!
It would be more convienent for them to fix it though.
*stares at arachnid and suki*
*or whoever else runs this*
Postby Fraxtil » 2009.05.13 (03:45)
This belongs in the Nmaps.net section, not the News section. Could a moderator please move it?
Also, I've never noticed any problems with a different URL. Why are you bothering to type the unnecessary 'www.' first, anyway?
EDIT: oh
Postby Exüberance » 2009.05.13 (04:07)
remove the www from the URL (but keep the http) and it works!
see?
Also, this is a forum problem, not a NUMA problem. The administators just need to update the NUMA tags to allow strings beginning with "http://nmaps.net/" and not just "http://nmaps.net/"
Nmaps.netNmaps.net
Postby Nexx » 2009.05.13 (06:12)
Where's LV? He'll be able to fix it.
@Gforce: He's not "bothering" to type the extra www, he's probably just copy-pasting the URL. (NUMA adds the www's as of recently)
Example for those confused:
Postby LittleViking » 2009.05.13 (06:40)
You've gotta make more sense in your posts, GTM. I fixed this up right away as soon as I knew it was a forum problem.
Edit: Actually, no one at all made sense in this thread. Except maybe Avarin. Props to Avarin for that.
Postby Arachnid » 2009.05.13 (08:36)
LittleViking wrote:You've gotta make more sense in your posts, GTM. I fixed this up right away as soon as I knew it was a forum problem.
Exactly. I saw this on uservoice and went "wha? What are NUMA tags?"
Postby MattKestrel » 2009.05.13 (12:45)
Aha. Sorry guys, my brain was frazzled after the exams. So yeah, I meant the thumbnails. :/
Postby Nexx » 2009.05.13 (17:27)
That's funny, my example still works. Only if I edit the post will the "www" one will work properly.
