Map "Demo" Packs
Moderator: zoasBE
Postby Tunco » 2009.04.05 (21:24)
So here is the idea:
Post a mappack that you have downloaded,
and post the demos,(completion demos,please)of the levels in that map pack.
Well I start with ChrisE's map pack So Simple.
And here is my completion demos:
(please specify that if you posted completion demos for every map in map pack,if you didn't,specify it as;"Except 5th map's demo,it has all other maps demos in this Map Demo Pack)
ChrisE's So Simple Map Pack,Map Demo Pack.(Except the demo of map "So Simple 2"):
Note:Completed So Simple 2.
Note: You can pm me if you want some map demo packs for specific map packs.
Another Note:To download map packs, search in posts, and find your map demo pack, there should be a link to download it also.
St. Atilla's Map Pack Map Demo Pack.txt
(48.99 KiB) Downloaded 225 times
Map Demo Pack of Strange Effects Of İmagination.txt
A Map Demo Pack of Map Pack of me
(4.73 KiB) Downloaded 212 times
Blackson's The BlackPack's Demo Pack.txt
Blackson's Map Pack's Map Demo Pack
(24.08 KiB) Downloaded 222 times
Map Demo Packs.txt
ChrisE's map pack So Simple Demo Pack.
(6.17 KiB) Downloaded 215 times
Postby Tunco » 2009.04.07 (12:53)
Since I'm the only one uploads demo packs,I will continue to post demo packs.
This time I will post Blackson's The BlackPack Map Packs Demo Pack.The BlackPack.
Completion for all of the demos.
The BlackPack Demo "AGD"pack(it means that all the demos are agd):
Blackson's The BlackPack Map Packs Agd Completion Demo Pack.
(24.08 KiB) Downloaded 224 times
Postby Pixon » 2009.04.07 (20:18)
How about instead of doing double posts, you put the demo pack into the main post?
Postby Rikaninja » 2009.04.08 (00:44)
I like the idea, but it all looks messy. I think you should think of a better layout to post it in. Also, maybe even a competition on this would be interesting :) It would be fun and you would be posting the demo's to map-packs the same time.
Postby Tunco » 2009.04.17 (18:38)
A map pack of Me.
Map Demo Pack of Strange Effects Of İmagination- By Me.
Map Demo Pack.
(4.73 KiB) Downloaded 209 times
Commodus
Postby Rule » 2009.04.25 (11:07)
You should place all the demo's in a first main post, so people will be more likely to use them.
For example, I don't want to search a 7 page topic for a demo that isn't even there ^^
Just an idea though.
So Simple Map 2 Demo.txt
The Completion on So Simple Map 2, that Tunco couldn't do.
(247 Bytes) Downloaded 211 times
Postby Tunco » 2009.04.25 (11:54)
Rule wrote:You should place all the demo's in a first main post, so people will be more likely to use them.
By the way I edited the 1st post, I completed So Simple 2 map, you can look to it. There İS that demo.
Postby EdoI » 2009.04.25 (21:07)
Tunco123 wrote:By the way I edited the 1st post, I completed So Simple 2 map, you can look to it. There İS that demo.
Quite off topic, I know, but how do you make that uppercase -i with a dot on top of it?
Postby Tunco » 2009.05.12 (17:53)
St. Atilla's Map Pack Map Demo Pack is here!
-And if you want some specific map pack map demo packs, you can pm me.
And link to the map pack topic to download it:St. Atilla's College For Ninja
(48.99 KiB) Downloaded 213 times
Postby Tunco » 2009.06.17 (16:17)
ChrisE's map pack demo pack!
You can download the map pack right here.
And the demo pack: (all agd)
ChrisE's Map Pack Map Demo Pack.txt
(18.98 KiB) Downloaded 247 times
