Problems on NUMA
Problems on NUMA
Postby n1nj4turtl3 » 2009.01.28 (01:24)
Hey all, i'm trying to upload one of my maps on NUMA and after I input all the required fields it says "Map data must contain at least one '|'", and so I checked and it does contain at least one '|'. So i'm not quite sure what's going on but i'd appreciate any help. Thanks =)
Re: Problems on NUMA
Postby n1nj4turtl3 » 2009.01.28 (06:03)
Yeah I got it. I was putting the info from the userlevels.txt into that field when it should have been the text from the editor in the game. =P
Postby Guest » 2009.04.07 (11:59)
I have the same problem, but I'm pasting from NED like I'm supposed to. This is the code for it.
Postby LittleViking » 2009.04.07 (13:27)
Guest wrote:I have the same problem, but I'm pasting from NED like I'm supposed to. This is the code for it.
You were missing some tiles. This should work.
Postby Guest » 2009.04.07 (23:22)
Worked like a treat, thank you ^^
Postby Neil_Bryan » 2009.04.25 (03:43)
I got the same problem too. I found out you must remove the asterisk (*) at the end then now it can be confirmed. NUMA puts asterisks automatically.
Names of Towns
Shortest: Y
