Hello, I'm new here
sorry for my bad english,....i'm from holland
I made more than 200 N levels
Is there a way to set them in episode's. So that I can make a N version of my own?
I would love that!
tank you.
Own Episodes
- Wizard Dentist
Hello Snaffer, and welcome to the N forums.
There is currently no way to create episodes for the game, however you can:
-Submit them to numa, the N user map archive: http://nmaps.net/
You will need an account to submit maps. In order to get an account on NUMA, download N, run it, click on 'configure', enter a username and password in the boxes provided, and click 'create new user'. You can then use that account to log into NUMA.
-Submit them to these forums as a map pack
You're already in the right section for this ;)
Just place your levels in a text file, make a new thread and upload the text file. Once you've done this, most people will know how to download and play your maps.
-Place them in your userlevels file, so that you are able to access and play them easily
Find the userlevels.txt that should in the same folder where you keep N. If it doesn't exist, simply create a new text file in notepad called "userlevels" and save it to the N folder. Open up the text file and write this at the top "&userdata=" (without the speech marks).
You can then paste the map data for your levels beneath that, and you will be able to play them in-game by clicking on the "userlevels" button on the main menu screen.
Make sure that your maps are pasted into the text file in this format:
$map name#author#type#map data#
Place the map data where i've written "map data". Don't forget the final '#' at the end.
I think that's all, shout out if you have any problems at any stage.
- Triforce
Tank you vey mush for you quik reply SkyPanda
I already user userlevel.txt to let my frend play my levels,
Too bed you can't make episode's, I would love to make 4 levels episode where you must save time too.
I touch maybe It was passible with user programs like N_Level_Data_1[1].1.zip that I found was for episode but it do'n work on my pc.
I think I will upload my levels idd to this forum, you think peaple wil really play them?
Must going on working, I at work now and many times when i make N levels too :)
bye
bye
- Steam: What's Steam
Maybe in N1.5 (if it comes out) there will be user episodes.
if29403 wrote:Maybe in N1.5 (if it comes out) there will be user episodes.
it comes out?
- NUMA Profile: http://nmaps.net/user/turtles
blackbelmoral wrote:if29403 wrote:Maybe in N1.5 (if it comes out) there will be user episodes.
it comes out?
M&R need to make money, too, and nv1.4 is a solid game.
then unreality might make an adlib n_v1.5 lookalike.
or someone else
or someone else
- Triforce
In N reality The maker at collums with files with the .SWF extension. So it must be possible to make own episodes.
If no-one nows how...Ill find out.
Uh...i'd be careful with that if i were you. Tampering with the .exe is illegal, and Unreality (creator of Nreality) got Mare and Raigan's (the creators of n) permission. It involves tonnes of coding, which took Unreality a while to perfect. I would start off submitting your map pack here, submitting some to NUMA, and getting critique on your maps before embarking on such an ambitious project. However, if you do fancy yourself as a coder, talk to M&R before you do anything drastic.Snaffer wrote:In N reality The maker at collums with files with the .SWF extension. So it must be possible to make own episodes.
Also, welcome!
