bufar's Neditor Nation Sigs
Postby bufar » 2009.01.21 (03:45)
I was bored a while back and made myself a custom Neditor Nation sig to showcase my progress in the tourney. Shortly after that, Hoohah asked me to make him one like mine. I did, despite knowing that I would have to update it every week. Now maxson has asked me to make him one, which I will, but now there's a catch. I will no longer update the center part (sorry hoohah!), but now I'm openly making them for anyone that wants one. Just tell me what color and text you want.
Postby Rose » 2009.01.21 (03:48)
Woo! ^^ Can I get mine in a color similar to my avatar? Thanks :P
Also, can you teach us how to update it ourselves?
Postby bufar » 2009.01.22 (04:39)
Here are the instructions to making the middle part. You will need GIMP to do this. Open a transparent image that's 200x100px. Set the foreground color to "cccccc" and the background color to "aaaaaa". Make a gradient going from the top of the image all the way down to the bottom. Then, go to "Filters" > "Noise" > "RGB Noise". Uncheck "Independent RGB" and hit OK. Then go to "Filters" > "Blur" > "Motion Blur". Set it to linear, set angle to 0 and length to 20. Now make a new layer. Use the text tool to type whatever you want to be in the image. I used "Agency FB Condensed", a default font. If you use multiple text layers, hide the first layer and do "Edit" > "Copy Visible", then paste it into a new layer. Select the first layer and go to "Filters" > "Map" > "Bump Map". Set the bump map to be the text layer and hit OK. You should get something that looks like the center part of my sig.
Postby 29403 » 2009.01.22 (08:26)
Make me a bluey green one, with my name and my member number please!
