Jump Pad/Wall Glitch
Do you own a copy of Metanet Software's console and handheld title? If so, talk about it here!
Postby Universezero » 2009.01.14 (23:14)
This has already been done, this is just another way to do it.
Red = Jump pad
Grey = Tiles
Set tiles up like this, get ninja to jump up into the pad. Ninja will stay stuck while jump pad continues pushing. Press jump again and you will be launching into the wall. You will now be inside the wall and still be alive.
I have N+ DS; I'm not sure if it works on the other versions.
Gross
Postby everythingfromatoz » 2009.01.15 (18:04)
Whoa! But I can't find my ds, does it kill him after a while?
Postby Universezero » 2009.01.15 (21:16)
everythingfromatoz wrote:Whoa! But I can't find my ds, does it kill him after a while?
No.. He just jumps around in the wall. He only dies if he leaves the playing field.
Postby nnn » 2009.01.15 (22:08)
UniverseZero wrote:This has already been done, this is just another way to do it.
Nice job, it finally works on the PSP.
English isn't my mother tounge, sorry for any mistakes.
Postby alex » 2009.03.18 (01:02)
I just found another way to do it in DS(dont know if PSP)
Put 3 vertical locked or trap doors right next to each other and wall on either end. then put N on them and don't move. he sink through. from there you can get into walls and stuff by moving(though sometimes it takes afew steps). The best part: this will work in midair if the walls are there, and can be made to appear or go away with the switches.
it is not the end, nor the begginning of the end, but perhaps only the end of the beginning.
92% of teens have moved on to rap. If you are part of the 7% who still listen to real music,
