You are a drone, KILL!
- Gross
My first game ever! And first time using gamemaker.
Ever wanted to be a drone? Think the drone? Well heres this game!
screenshot for some peeps:
Also, I threw in my second ever pivot animation!
- Gross
Using the motion tool should be no different than adjusting it's coordinates. All the motion thing is, is really a built in "class" (if GM had classes, it would be one) that adjusts co-ordinates every fram based on the set variables speed and direction. Ever since I started using GML instead of the drag-and-drpo (so pretty everything exept half of a game) I've just manually changed co-ordinates every frame based on my own _speed and _direction variables.EdoI wrote:I was using GM for a month and I made one game. Then I stopped for a year and now I'm using it again. I'm still in learning phase so I don't know how to work in 3D, but since you're using GM Lite you couldn't even if you want to. I work in GML so if you need some help, you can ask me some stuff. You're using drag&drop? Try using horizontal/vertical speed instead of move fixed option. That will make your motion smooth. Feel free to ask anything but don't forget that I'm still learning.
*sigh& GM would be so much awesommer if it supported classes and objects. Instead you have to use only static functions and pass pointers to them. Actually, you just past integers to them that have nothign to do with memory locations. Oh well, I guess it IS a learning language, not a high-level OOP language. Too bad it's not both :D (though it does pretty well)
- Gross
Well, drones don't get killed by mines :)everythingfromatoz wrote:What about my GAME!?!?!
Oie.
- Gross
- Gross
I would have taken this in the direction of a puzzle. Mines shouldn't kill drones, however, normal doors, locked and trap doors should impede the drone, making it harder to catch/kill the ninja.everythingfromatoz wrote:I know. But what else is there?
The bottom-left pixel must be the same colour as the background. This is how it determines what the background is. Also the background must be ONE solid fill, not a jpeg'd textury semi-solid colour.everythingfromatoz wrote:Yea, the transparency wasn't working.
Another possible cause is that it MIGHT not allow transparency in the free versino if that's what you;re using.
- MBTI Type: ISFP
No it does, i've made about a couple dozen crappy games until i quit about 3 months agoExüberance wrote: Another possible cause is that it MIGHT not allow transparency in the free versino if that's what you;re using.
you forgot to add a homing turbo
you forgot to have an animation change depending on direction
drones can go through mines
drones cant go through doors
you forgot to make the
last words.blackbelmoral wrote:you forgot to add a loading bar picture
This.blackbelmoral wrote:you forgot to have an animation change depending on direction
And diagonal movement.
AND I GOT SPAMMED WITH TEXT BOXES.
Gold is evul.
- Gross
and you should also change the drone's picture cuz normal drones don't do this
i have used gamemaker and made a basic maze game...
- NUMA Profile: http://nmaps.net/user/RedSham
I have GM...and ive never used it.
For constructive criticism... diagonal movement, and no stop-start movement would be great. Also, maybe restart the demo level as opposed to having a message box, because then it doesn't allow movement and all sorts of things happen.
Also, bit pixel-y, an it would be cool if the drone turned depending on which way you were going (and he can't really be homing, can he?).
