Tricks
Moderator: EddyMataGallos
- Pure
Believe me there's no magic trick, the only way to learn is to practice with different situations heavily and get used to the feeling. As a general rule for bounce block double/triple top/side jumps though, is that you should train your timing correctly, that's the key concept, it's definitely not just mashing the key 2/3 times as quick as possible, that doesn't work, just like it doesn't work for triple tile jumps (which are possible in 2.0 as well, but a little harder than in 1.4).
- Pure
at least, i could do the other tricks .
i will continue to try.
- Pure
is it timing or what?
are you pushing the jump button two times?
jump middle of the block and jump?
i will be happy if anyone explains the trick.
- Pure
yes. to do it you must be very fast i think.SpartaX18 wrote:One block jump? Do you mean a pop? That is, a frame-perfect stationary wall jump (like in 02-4)?
It's really easy to do with pausing, but i'm absolutely not encouraging to do it this way (may cause severe conscience issues).
