I was working on a level for a little while, and I moved the character around, and suddenly I was controlling the second character instead (Co-op level), so I deleted the second character, and tried to test again, but N disappeared when I tried to test it, so I pressed undo until he was back in his original position, and now both of them disappear when I try to test it.
This is a huge bummer because I put a lot of work into this level, and I'd rather not start over. Has anyone else encountered this problem, and maybe found a way to fix it?
Can no longer test my level?
- Almost as Bad as One
To anyone else having this problem, I apparently placed a character in the wall at some point, and so it kept reverting to him as player one, I just deleted everything temporarily to find him since his model doesn't appear on top of the wall pieces.
- Octave
