Check out my score on "drone surfing 2" www.thewayoftheninja.org/nv2.html?l=157315
156. The level is the exact same as 55-0, apart from 1 block replacing a 1 way tile. It appears that as you walk from a block surface to a one way tile surface, you lose a frame. Can anyone get 156 on 55-0? Has anyone noticed this before?
Is this mechanic in anyway related to the level 9-3 maxing at 55 as well. Is there a way to negate this by finding a hidden half frame?
It may be that this is responsible for both levels maxing at odd numbers... Even number theory has been confirmed everywhere else.
What are your thoughts?
-cooperverdon
55-0
Moderator: EddyMataGallos
