Have you found any bugs that werent supposed to exist in gam
Postby blackbelmoral » 2008.12.04 (15:51)
es?
what i mean is that staff said that they were impossible. look at the october nintendo power issue. im a mariokart nut, and they said that you cant dodge a blue shell in Mariokart DS. Well, ive done it several times with power-slides and mushrooms. what about you?
YAR HAR!
X2
Sigs:
29403|?NicNac?| Kablamo
Postby smartalco » 2008.12.04 (17:28)
No I haven't found cheats in games that don't exist.
Postby Luminaflare » 2008.12.04 (21:31)
I was the first to discover most of the cheats for team buddies on the PS1.
Postby Izzy » 2008.12.04 (21:52)
blackbelmoral wrote:what i mean is that staff said that they were impossible. look at the october nintendo power issue. im a mariokart nut, and they said that you cant dodge a blue shell in Mariokart DS. Well, ive done it several times with power-slides and mushrooms. what about you?
I'm awesome at blue-shell dodging. I easily do it with powerslides but can't do it with 'shrooms.
Postby spudzalot » 2008.12.05 (00:16)
On Smash Bros (in team matches) there is something called wobbling where one person grabs you then presses the attack button until you fall out of the grab then the other person grabs you and does the same thing. And it just goes on back and forth until you get to a kill percentage. Its supposed to be impossible to escape but I started button mashing and bounced really high out of the grab and couldnt get grabbed again.
I guess that counts, if it makes since... :/
Postby blackbelmoral » 2008.12.05 (02:07)
do yuo mean in wii or ds?
YAR HAR!
X2
Sigs:
Postby mattk210 » 2008.12.06 (08:35)
spudzalot wrote:On Smash Bros (in team matches) there is something called wobbling where one person grabs you then presses the attack button until you fall out of the grab then the other person grabs you and does the same thing. And it just goes on back and forth until you get to a kill percentage. Its supposed to be impossible to escape but I started button mashing and bounced really high out of the grab and couldnt get grabbed again.
http://super-smash-bros.wikia.com/wiki/Team_Wobble
It's known.. unless you made that article
Postby Yoshimo » 2008.12.06 (21:09)
I get what you mean, but no.
By the way, it sounds like you're saying ''Have you ever had a game that didn't exist, then found a cheat for it?''
Postby isaacx » 2008.12.13 (17:43)
no, i think it means "have you found a game that has a cheat that was appearently... whatever.
Postby SlappyMcGee » 2008.12.13 (18:17)
Uhh. Well, I suppose this might refer to the elastic band trick for TTFATF in GH3.
(That's a lot of acronym to absorb if you don't instantly know what I'm talking about.)
Postby Xious » 2008.12.14 (14:26)
SlappyMcGee wrote:Uhh. Well, I suppose this might refer to the elastic band trick for TTFATF in GH3.
What you're talking about is a "hack" or mod for a game, like putting a rubberband over the grean button to pass the hammer-on intro of Through the Fire and Flames in Guitar Hero (lol knew what u meant)
He wants to know if you have proved someone wrong by doing something on a game that people said was impossible.
Postby Snuggletummy » 2008.12.14 (18:09)
Actually, that's not a hack or a mod in any way. In fact, that IS indeed a trick. See, hacks change a game's coding, and mods change the game in general, like... changing the game's perspective, or changing the rules of the game.
Postby Luminaflare » 2008.12.14 (18:09)
A hack is messing with a games files to cheat. A mod is changing or adding to the games files to add more to the game or make a different game. Putting a rubber band on a controller is neither of these, it's not even an exploit (which is taking advantage a bug or glitch in a game for your own benefit).
Postby Xious » 2008.12.14 (19:18)
http://www.youtube.com/watch?v=GtHN1YE_mYc
If this is considered a mod, so should the TTFAF rubberband trick
Postby Luminaflare » 2008.12.14 (21:40)
But that isn't a mod...
Postby SlappyMcGee » 2008.12.14 (22:02)
Modifications and hacks both refer to changing general code about the game. The first instance refers to changing the game to expand it, and the second generally refers to gaining an advantage in the game.
Cheating a game is just a manner of gaining an edge in a game, whether it be through traditional codes or by changing something. Playing the torture scene in MGS1 with a turbo controller isn't modifying the game; it's cheating it.
And I found this trick rather before most others did, so there's that.
Postby notsteve » 2008.12.17 (00:17)
i've never played a game that didnt exist
Postby Mosh » 2008.12.17 (01:36)
In Fallout 2, there's a window in San Francisco that can be shot into, but not out of. Your character is invisible to all those inside when you're standing outside, but you can see/aim/fire at all people inside. I used this to bypass a very difficult boss-type showdown.
[my small, lightweight signature gets 65 miles to the gallon.]
[hows your clunky signature doing in the mpg-department?]
Postby Zephyr » 2008.12.24 (12:02)
Alot of those dodgy sites on the web give cheats that dont work...i hate them =/
Clickme
Postby a happy song » 2008.12.24 (14:02)
I don't think so.
I've found numerous bugs and glitches by experimenting when I grow bored with a game.
Closest I've dome to this: I typed 'Aunt May' into the secret code field as soon as I loaded Spiderman on the PS2, just to see, and it unlocked every cheat in the game.
Postby Luminaflare » 2008.12.24 (21:26)
I'm ridiculously good at exploiting physics based games. In BK: Nuts and bolts I had about 90% of the crates before I'd even got my second jiggy.
Gross
Postby everythingfromatoz » 2009.01.06 (15:35)
Well, I played a game called Treasure hunt, by ebrainygames when I was 9, the game spazzed out and gave me about 100million points,
NO LIE!
http://www.ebrainygames.com/cgi-bin/loa ... games.html
Also, on supermario galaxy, I got a blast from an ememy to throw me under ground.
Postby blackbelmoral » 2009.01.23 (17:22)
BionicCryonic wrote:I get what you mean, but no.
relatively fixed; line too short for all the words
YAR HAR!
X2
Sigs:
Postby 29403 » 2009.01.23 (17:37)
The only games I could play were when I was born, before my parents took them off me, so I found a few bugs in Sonic 1, where if you go to some place in the second zone where lava chases yo and you go in it, wait for a bit and he'll die, while walking...
Postby smartalco » 2009.01.23 (19:37)
Whoever retitled this topic, you have no brain
