10th anniversary insomnicon
Postby ska » 2014.03.31 (19:50)
Going to host on IRC (#n)
Rules
1) Time/Date: TBC
2) Absolutely anyone will be able to join.
3) I am a freelance game designer, so plan on having a mini-game challenge for every hour until there is one left. Most challenges will be fairly simple, but in order to win, you will need to complete each successive mini-game without fail. (Will probably rehash existing games to save time/effort.)
4) Each mini-game will be protected by a secret code, so they can only be played in the hour proceeding the release on #N.
5) Upon completion of the mini-game, you will receive a completion code. I plan to make these codes unique to prevent collusion
6) You must be able to run .exe applications to compete. (So if you're running mac, you'll need parallel or bootcamp - that shouldn't be a problem) Operating Systems like Wine also usually work.
7) Register your interest here - although, it's not compulsory. It'll just give me more motivation to make it better.
Edit: if this gets at least 5 comments of support in 24 hours, I will endeavor to make this happen, otherwise I'll abandon it.
Postby Vyacheslav » 2014.03.31 (20:53)
Couldn't you also create OS X binaries as well?
Postby ska » 2014.03.31 (21:29)
Vyacheslav wrote:Couldn't you also create OS X binaries as well?
What am I, some kind of magician? :D
Postby zoasBE » 2014.03.31 (21:32)
Ben demands comments. Please comment, I want to see those minigames.
2/5
just as friends as enemies
even fewer friends
Postby zoasBE » 2014.03.31 (21:36)
2/5 is not a rate, is the number of comment of the 5 required... :P Double posting counts?
even fewer friends
Postby Donfuy » 2014.04.01 (15:06)
Huh...a 10th Metanet Community anniversary where we play...your games? I'm not sure if that makes any sense.
Postby ska » 2014.04.02 (11:06)
These challenges are just fun ways of ensuring people are staying up for the insomnicon, and it prevents cheating...
