Post a Run!
Postby ToeFaceKiller » 2009.08.09 (16:32)
4156 speed
Postby TheRealOne » 2009.08.09 (18:34)
ToeFaceKiller wrote:4156 speed
Taken. I missed the corner shove on the thwump so it could be faster.
vankusss wrote:177170 hs and sr (chimney-ing map)
Speed Taken, I had 223.450 with a -1 for highscore =(
Postby 999_Springs » 2009.08.09 (19:55)
vankusss wrote:but you are actually playing levels, so set the irc up
#N or #N-highscores? (Or both?)
Postby vankusss » 2009.08.09 (21:05)
i was on #N only few times and people there were never talking about anything related to N, so go to #n-highscores
Bacardi
Postby Meta Ing » 2009.08.10 (02:44)
Kind of killed your and TRO's runs...
Quotes (Click to open):
Kablizzy: Click
TOO BAD!
Postby natrues peril » 2009.08.10 (11:57)
81139
81142
by nicnac
Postby Kool » 2009.08.11 (03:38)
00-0 SPEED
^____^
Postby vankusss » 2009.08.11 (10:05)
Kool-aid wrote:00-0 SPEED
^____^
gj :-O
Postby Unreality » 2009.08.11 (12:11)
^____^
:OOMG
Postby glib_jase » 2009.08.11 (22:40)
15469. The end of the run is messy, but would like to see if someone can reverse CJ off the exit platform to hit the switch.
Postby golf » 2009.08.12 (01:34)
I improved my ep 90 highscore (Sorry kk :D) In the process of getting a 3rd place run, I happened to take 90-4 from xaelar.
Postby ska » 2009.08.12 (15:16)
wowzers i think i made a mess in my trousers. nice 00-0 speed and tight ep 90 run, golf. congrats on another 0th.
Postby natrues peril » 2009.08.12 (19:22)
31723
31732
by nicnac
Postby jasdanu » 2009.08.12 (23:36)
177533
Sig: Izzy
Postby natrues peril » 2009.08.13 (14:16)
148516
by nicnac
Postby Tunco » 2009.08.13 (15:34)
natrues peril wrote:148516
natrues peril wrote:31723
Both taken. (speed)
Postby darkshadow » 2009.08.13 (17:08)
Faster method on 19-0:
Edit: Nice job tying golfkid on 94-0 kool-aid.
Unreality's awesome mod
Postby golf » 2009.08.13 (20:23)
Dark: Nice slightly modified route on 90-4, but still... GRRR for taking my 0th!
Also, I'm tempted to tell Kool-Aid to try 94-0 on highscore mode, but I'm scared that he'd get that little bit extra improvement and take that one too...
Postby darkshadow » 2009.08.13 (20:28)
golfkid wrote:Dark: Nice slightly modified route on 90-4, but still... GRRR for taking my 0th!
You can probably take it back as my route has at least a tenth of a second left and probably more.
Postby golf » 2009.08.13 (20:29)
Could be, but it'll have to wait at least a day, and probably more. But I guess I can give it a try. Did you get lucky with that third drone in the vertical shaft at the end, or were you able to consistently avoid it?
Postby darkshadow » 2009.08.13 (21:31)
golfkid wrote:Could be, but it'll have to wait at least a day, and probably more. But I guess I can give it a try. Did you get lucky with that third drone in the vertical shaft at the end, or were you able to consistently avoid it?
Not quite sure which you mean but after drawing the drone at the start and making it up for the first vertical wall-jump the route is fairly simple so far as I remember. However I did get 0th first clean completion so I don't really know.
Bacardi
Postby Meta Ing » 2009.08.14 (01:24)
Earlier today, TRO and I discovered that you can walljump between launchpads closer than one tile apart...
Here's my 89-2 run, with the map slightly edited to show you what I mean... (I put launchpads between the existing launchpads)
Kablizzy: Click
TOO BAD!
Postby natrues peril » 2009.08.14 (12:47)
that owns meta
110383
150249
by nicnac
Bacardi
Postby Meta Ing » 2009.08.14 (19:09)
145535 highscore. I'm coming really close to pulling off Road_rage's (supposedly FBF) method. The only thing I missed was the final corner jump at the end - I did a walljump instead.
Also, 177567 speed.
Kablizzy: Click
TOO BAD!
Postby Unreality » 2009.08.15 (06:46)
I accidentally made a corner jump at the red circle on 08-0, and it seems that it is quite a bit faster:
edited: forget about it, the top drones are limiting your speed... oh wait.. maybe not :P
