For whatever it's worth, when I took the 0th on 79-2 I independently found that innov and used it, believing at the time that nobody else had ever used it or even found it. I don't think I ever improved on that run, and even if I did certainly didn't change the route, so if you look at my run there you'll see how I used it at that time.ska wrote:Haha... That's hilarious. Not only did you do the innov—I did it ages ago but evidently forgot that I did. Good to know that at least his innov was made use of .EddyMataGallos wrote:This is level 79-2, and the innov was already implemented.ska wrote:It's been nearly seven years since spect passed away. As I was going to his YouTube channel to reflect on his memory, I saw again this old innovation: https://www.youtube.com/watch?v=FZC3tUs9Krc
I can't remember the level name, but do you think this could help in a run (or is it redundant)?
The red dots indicate jumps, and the blue line was just an alternate idea. I have no idea how quick this route is, but my hope was that some of the active highscorers could give it a test run.
By the way, Raif, I think the fabled quadruple bounceblock jump could be done in an MBD for this level in at least once place. What do you think?
Blocked by a drone at the last bit. But even then I think I'm only about 20 frames faster than Eddy, so I'm not sure if this route is actually faster. An MBD of the current 0th route could save a similar amount. The quad and the first corner triple couldn't be incorporated into the run because they were too powerful.
Demo here: http://forum.droni.es/viewtopic.php?f=2 ... 71#p177071
I've been sitting on this 27-1 innovation for years. I'm wondering if this is doable, but I can't be bothered testing.
It's used in speedrun so I think it might be possible.
It might be possible to get the corner jump you suggested and escape from the seeker just in time but only if everything else is executed perfectly.
And you're just the man for the job! I expect to see a new 0th on my desk by the end of the month!macrohenry wrote: ↑2020.03.16 (16:12)I found another route change at the start of 27-1 speedrun but ran into a problem later:
He's experimented with van, and beating the drone by going under the 45 degree tile is possible and about .300 faster:
Surely this is doable, I suspect even real time. From the perspective of an MBD, we wonder if it's even possible to enter the chimney before the drone.
