Tool-Assisted Highscores/Speedruns
Postby Raif » 2018.09.09 (21:13)
golf wrote:I'm particularly interested to hear for sure exactly how that input buffer works, makes sense. Would you be willing to look at the buffer in the opposite direction, when you jump after running off a surface? I feel like that works a bit differently, where it will still let you jump even when you're not physically on the surface anymore.
I'm willing to look at that sure, but first I need an idea for a level that can be used to test that. Can't think of anything at the moment.
The other case is easy to work out from a one tile width chimney. I think it's best explained in the form of a table.
The first row is what I believe to be a perfect chimney. The sequence of a perfect chimney in N++ appears to be jhnjhnjhn... and so on.
The second sequence is a test case where I simply jump the first frame it is possible to do so. So to start off a jnjnj sequence gives a output of three jumps. But then you try to do a fourth jump you find that the game won't accept an input for the fourth jump until frame nine. From this you can conclude that the ninja does not always jump on the same frame as the keyboard input. If it did then you should logically be able to do the fourth jump on frame seven.
I'm not sure about the actual sequence of jumps physically taking place without FBF, but it doesn't seem to match the inputs. The opposing wall can't be magically further away every other jump.
Postby ska » 2018.09.11 (02:22)
I don't want to tamper with my N++ files; can someone please upload a video of the run for me?
Postby Raif » 2018.09.12 (15:19)
ska, I assure you it's perfectly safe.
18-4 Highscore (105.475, 0.800 faster than Eddy)
First half of route by ska.
Postby EddyMataGallos » 2018.09.12 (19:31)
Very clean, I updated the master list to contain all the new MBD's (since 2014): https://pastebin.com/ZWMErCyT
Alternatively,
MBD Collection (188 Demos).txt
(440.24 KiB) Downloaded 970 times
Postby Raif » 2018.09.13 (12:32)
Thanks, Eddy. I added your updated link to the OP.
Postby ska » 2018.09.14 (06:57)
Oh, that is really nice...
May I ask how long both demos took to make?
Postby Raif » 2018.09.21 (10:49)
If I remember correctly the first demo took 4-5 hours and the second 2-3.
Postby ska » 2018.09.21 (16:23)
Raif wrote:If I remember correctly the first demo took 4-5 hours and the second 2-3.
Geez... I really respect that. We should make a Kickstarter or something for Raif to make more MDBs lol.
Postby Raif » 2018.10.24 (00:31)
73-3 Highscore (112.950, 2.275 faster than Eddy)
Postby ska » 2018.10.25 (12:17)
Raif wrote:73-3 Highscore (112.950, 2.275 faster than Eddy)
Savage demo.
Postby EddyMataGallos » 2018.10.26 (00:22)
Great job pulling the innov in this map, blazing demo.
Postby ska » 2018.10.28 (08:36)
I have a request for Raif: Do you think you could live stream your next MBD creation? I'm really curious to see your process. We could also offer suggestions in chat.
The Loneliest Number
Postby euni » 2019.01.28 (01:20)
N++ works without much of an issue in libTAS. Here's a quick demo I made: https://www.youtube.com/watch?v=qBE1Oq-WdTM
libTAS can be found here: https://github.com/clementgallet/libTAS, most of the information you would need is on that page or in the TASvideos documentation of libTAS.
Runtime: Virtual Steam client must be checked in libTAS for it to work. There are a couple issues with loading times and save data, but these would only really be a problem when starting from a new profile. Also, highscores done in libTAS will not overwrite legitimate scores.
Postby ska » 2019.01.31 (10:45)
Wow! This is exciting! I'll be following this with great interest. Hopefully Raif and others will see this and give it a go.
Postby Raif » 2020.01.14 (08:28)
61-4 Highscore (165.900, 6.475 faster than macrohenry)
Postby ska » 2020.01.16 (10:26)
Raif wrote:
2020.01.14 (08:28)
Wow, you straight-up clowned on the real-time route. I had completely forgotten that I had a 0th on this level before Macro sniped me by a frame. Is there a human-feasible route to be conceived out of your run, or...?
Postby macrohenry » 2020.01.16 (21:26)
Raif wrote:
2020.01.14 (08:28)
What the hell is this corner jump around frame 370? It almost seems too powerful to be true. Great work as always!
Postby ska » 2020.01.20 (05:37)
Yeah, it looks like a physics-defying jump. I think the extra velocity is because of the corner jump prior that boost the horizontal momentum. Regardless, this is a masterpiece. Definitely one of my all-time favourite MBDs.
Postby Raif » 2020.01.24 (01:52)
Yeah, it's because of the horizontal ck beforehand. Note I couldn't actually even hold jump for the full 31 frames because of the drones. Otherwise I could have pretty much cleared the ledge.
And a new MBD again, basic route is the same as realtime. Just modified a bit to include bbcjs and quads.
54-2 Highscore (131.600, 2.950 faster than macrohenry)
Postby ska » 2020.01.24 (03:53)
I'm loving this revival, dude. Can we expect to see any more? Are you open to requests? How long did 54-2 take to make?
Postby Raif » 2020.02.01 (06:03)
Sure, you can make requests, but I don't make any promises. About 4 hours I think. This one took about 5.
72-4 (113.950, 2.700 faster than jp27ace)
Postby EddyMataGallos » 2020.02.01 (17:32)
I just saw the last few MBD's, thanks for the awesome work Raif ;)
Postby ska » 2020.02.03 (06:56)
Delectable demo on 72-4.
A few suggestions I have are 85-0, 85-3, 99-4, and 74-3.
I'm curious if some thwump-jumping shenanigans can be utilized to save time on 99-4.
Postby vankusss » 2020.03.14 (21:37)
Raif wrote:
2020.01.14 (08:28)
Well that's just ridiculous.
Postby Raif » 2020.04.11 (00:36)
43-0 Highscore (167.350, 5.750 faster than Eddy)
