Moderator: EddyMataGallos
Also, played 52-4, got 2nd place. I believe the way I fall through middle tunnel is faster. Check user map ID: 239888. Even tho I executed same beginnin' as Voted, and even more important, same ending as him, I am still about 20 frames short. I think I lose much frames within the part of the map where gold is. I encouraged you to play it! :D
Also, way to go for tailow for some runs, I have checked earlier when I had time... Like that 121 run on 84-2 and also tying few probably maxed levels. Also, beating me in 52-3 by almost a second. I tied that now, but the run is wow, even easier than the one used by players before.
Also Velocity got two 0ths, I guess. Icy Sole with great runs on metanet levels. Also, Mr Doge, got back, for a bit, with several top10s too. :D
[Edit #1] 5.7.2016.
I just improved 98-4 by a lot. Did another thing I had in my mind for long time now which gives 400 frames in very beginning. I tested it in user level ID = 244733. I do lose much of the lead due to my extreme caution (yes, caution involves shaving the drone xD). I believe there is 200+ more frames left just with better finishing.
EDIT: Forgot about 12-0 + i just took 14-0.
- 20-2
- 26-3
- 27-1
- 27-4
- 30-0
- 30-2
- 30-3
- 31-4
- 32-0
- 35-0
- 36-2
- 38-0
New ones include:
- 38-4
- 39-0
- 41-1 (just untied)
- 41-3
- 43-2
- 43-4
- 44-2
- 45-2
- 46-3
- 47-3
- 50-1
- 50-4
- 54-1 (retaken)
02-3 - 9th. [Ben Schultz, 6598]
09-3 - 8th. [Ben Schultz, 6555] [Possibly maxed]
09-4 - 5th. [Ben Schultz, 16066]
10-2 - 7th. [Ben Schultz, 5865] [Possibly maxed]
33-1 - 8th. [Ben Schultz, 9504]
41-0 - 6th. [Ben Schultz, 5123]
51-4 - 6th. [Ben Schultz, 9446]
55-0 - 9th. [Ben Schultz, 5155] [Possibly maxed]
60-0 - 7th. [Ben Schultz, 7343]
63-0 - 4th. [Ben Schultz, 7043]
71-4 - 9th. [Ben Schultz, 11846]
90-2 - 3rd. [Ben Schultz, 7616]
101-2 - 4th. [Ben Schultz, 17152]
101-4 - 8th. [Ben Schultz, 10171]
102-4 - 5th. [Ben Schultz, 6028]
104-1 - 6th. [Ben Schultz, 7174]
107-2 - 5th. [Ben Schultz, 15110]
108-4 - 4th. [Ben Schultz, 12996]
113-3 - 9th. [Ben Schultz, 13034]
113-4 - 7th. [Ben Schultz, 10035]
118-3 - 2nd. [Ben Schultz, 8557]
119-3 - 9th. [Ben Schultz, 5692]
119-4 - 7th. [Ben Schultz, 2919]
As of 29th August 2016.
Thank you, btw.
I checked some of the scores oxy posted, and they are correct.
Hmmm, not sure what I was mixing it up with. Thanks.XandoToaster wrote:118-3 refers to b8-3, 104-1 refers to a4-1, etc.
