Postby darkshadow » 2013.03.14 (04:00)
Slightly faster gold chamber route on 4-1 (I know I missed a gold in the demo. Its not that tough to AGD).
Edit: Also, no idea if this can be made to work but if you can dodge the rocket it's faster (34-2).
Unreality's awesome mod
Postby vankusss » 2013.03.15 (18:41)
I feel there are few seconds hidden on 93-4, I just can't find them. I tried this afternoon, this are the things i found:
#1 there are many routes to the left side, none of which i found suitable
#2
It continues like this: (it's also a practice map)
You can try to find the rest of the route on this map (the hard drone is deleted - make sure it doesn't cause any problems later in the run)
edit: just posting this in case anyone has a lot of time and wants to keep exploring...
Postby TheRealOne » 2013.03.15 (22:07)
That map hurt my brain van. Just so much going on with those drones. I agree with you though. I think there is with out a shadow of a doubt a better route in that map. I think you are on to something with that that slip under the drone idea. If you get that and continue some what the same as the other route you might be able to avoid what happens to Eddy in the current route on the third valley from the left where is he is forced to wait for the drones. Obviously there may be a bottle neck somewhere else, but since you also got different gold groups on the way out in your first demo it may be possible to avoid those theoretical bottle necks as well.
Postby darkshadow » 2013.03.15 (22:54)
See my top-20 run for a much faster start on 91-4. More than enough to solidly take 0th.
Also, if anyone wants a top-20 on 15-3 my route is incredibly easy. I also have a slight modification that might be able to take 0th. See below for crappy example
Postby TheRealOne » 2013.03.16 (02:06)
I would love for someone to throw down an epicly clean run on that map. It has been the one level that has avoided control by the community. There has been a years long battle between x-y-z, 7aMaDX, and TWA. LAT is the only one of us to even make a some what decent attempt at it. Even Lim the master of cleaning super long hard runs is 5 seconds of the pace.
Postby golf » 2013.03.16 (02:32)
*2 days later*
EddyMataGallos wrote: Took 91-4 by 2.5 seconds
Postby darkshadow » 2013.03.16 (06:34)
TheRealOne wrote:I would love for someone to throw down an epicly clean run on that map. It has been the one level that has avoided control by the community. There has been a years long battle between x-y-z, 7aMaDX, and TWA. LAT is the only one of us to even make a some what decent attempt at it. Even Lim the master of cleaning super long hard runs is 5 seconds of the pace.
I agree getting a really clean run is obscenely difficult. That's why maximizing the start is so important. Here's an even faster route (though I haven't confirmed if the last chaingun dodge is possible).
Edit: Potential way around that:
Gross
Postby jp27ace » 2013.03.16 (14:03)
vankusss wrote:I feel there are few seconds hidden on 93-4, I just can't find them.
I've had a little look and come up with a route thats about 2 seconds faster, but I suck too much to pull it off, and I have no idea how to save a replay of half a run.
Postby TheRealOne » 2013.03.16 (14:21)
I've had a little look and come up with a route that's about 2 seconds faster, but I suck too much to pull it off, and I have no idea how to save a replay of half a run.
If you are using NReality when you die from anything in game other than suiciding wait for the message box that says press space to play again or r to replay your demo. At this point press "SHIFT+R" and then a webpage from infunity.com (the hosting site for NReality) will pop up, just copy the text that appears on that page. When pasting that on the forums use the
Gross
Postby jp27ace » 2013.03.16 (14:59)
Ah awesome thanks TRO, testing:
Hopefully the end of the run is obvious (pretty much do the mirror of the LHS)
Edit: Is there any way to ghost against a run where you die?
Edit 2: Took 19th, missing half the gold but showing the full route
Postby vankusss » 2013.03.16 (16:45)
jp27ace wrote:Ah awesome thanks TRO, testing:
awesome!
Postby macrohenry » 2013.03.16 (17:12)
Really awesome route change, jp! It's around 2 seconds faster than the current 0th route, but much harder, I guess.
Postby EddyMataGallos » 2013.03.16 (23:13)
Woah great route change indeed jp. Obviously harder, specially to AGD, but its worth it.
As for 91-4, I remember I discussed with Raif one day about a faster start we had both thought about which turned out to be the same, pretty much the same you showed as well dark, basically maxing it out. The problem with that level, at least for me, is the awful top part. I have never been able to realize a consistent way of doing it (like top players do) which doesnt depend on, you know, randomness.
Postby darkshadow » 2013.03.28 (21:24)
Here's an change to the the beginning of 94-3 that's about half a second faster. There are two ways of doing it. Only the start is relevant in the second demo and its the slower way of doing it (I just played out the rest for the heck of it, no other innovations).
Edit: And I have no idea why no one uses these openings for 37-4. They aren't much harder than the normal one since you can just insta-suicide if you miss the triple jump.
Postby TheRealOne » 2013.03.28 (23:49)
Very interesting Dark. That is downright clever. And it is right the the start of the run so its not a big deal that it isn't the easiest trick. Well found.
Postby darkshadow » 2013.03.29 (01:15)
Is there any chance that my opening on 59-4 could be fast enough to beat the bottleneck at the top?
Postby EddyMataGallos » 2013.03.29 (01:35)
There's a problem with your route and going fast:
If you try to go even faster:
Maybe going this fast and trying to sneak below the drone:
Same idea but better:
Not sure if possible or moreover if fast enough.
Postby darkshadow » 2013.03.29 (03:58)
I didn't mean going faster at the bottom. If you compare my run to the top 5 you'll see that delaying to set up the drones properly is faster than the route they use. I meant can the ascent be done perfectly to beat the top middle drone. However, I do think that last run of yours is promising and if pulled off could probably beat the top drone.
Postby vankusss » 2013.05.12 (18:14)
I dunno if anyone can do anything with this, but I'll leave it here anyway (35-0)
Postby vankusss » 2013.05.12 (18:19)
vankusss wrote:I dunno if anyone can do anything with this, but I'll leave it here anyway (35-0)
EDIT: So I pretty underestimated this, looks like 20-30 frames:
EDIT2: HOPS I USED QUOTE INSTEAD OF EDIT FIRST TIME
anyway I took it so these posts are outdated
Postby macrohenry » 2013.06.22 (14:59)
This happened by accident.
Do you think it will help?
Postby _danielr_ » 2013.06.22 (21:33)
Yeah - if you can repeat it! ;)
What level is that? (is there a way I can find out?)
Nice 196592 sr earlier btw
Postby ska » 2013.06.23 (05:36)
_danielr_ wrote:Yeah - if you can repeat it! ;)
It's 39-4; a level notorious for ruining episode runs ;)
Postby macrohenry » 2013.06.23 (07:55)
Yes, it's 39-4. But I see a problem here: How do you continue after the thwump push? The thwumps at the top block you. :/
Postby golf » 2013.06.23 (18:08)
I got that a few times when I was trying that level a long time ago, and I ran into the same problem as you of the thwumps blocking me. That is, when I wasn't completely surprised and was actually able to try and continue :P Maybe if you could somehow control the height of the thwump boost, you could avoid triggering the bottom one and continue as normal on that side.
Users browsing this forum: No registered users and 44 guests
