As I said, I did that trick once on the left side, and now I can do it pretty consistently, too (the key is holding 'left' during the jump). Anyway, this is the new 0th route: (this was my first try skipping top left gold jump on the block, so I dunno how exactly the drones can move after)golf wrote:I don't think you can use my trick on the left side, because you need to be coming at the bb from the side with a decent speed, and not from above. Otherwise a very good route, I agree it probably is able to be Analu's time.
gracias, hermano!EddyMataGallos wrote:Those are some frickin' sweet innovs ska, Im sure 0th can be attained with them, definitely gonna try those out soon :D
buena suerte!!
Nice... If you got a better kick off the thwump, I think you could pinch it.vankusss wrote:60-2, dunno if faster, but cooler :D
If you can sneak in between those 2 bottom mines on the right then collecting that gold should be very fast and you should be able to beat the drone coming back over the top. The CJ can take you through the gap in the mines above but at that angle and speed (along with the drone hampering you) you end up slowing back down and no better than the standard "old" route.
THE question is, will it be faster? The best time i see on the boards using the old route, is 124.225, almost 2 seconds behind Izzy. Does beating the drone at top gain you 2 seconds?glib_jase wrote:60-4, variation of the "old" high scoring route:
As for that 60-2, i tied 0th with it a while ago, so it's definitely faster. I would have probably taken it if I'd let go jump few frames sooner. (i have no idea what times i used in this sentence)
Here is the file. I haven't updated it for like 6 months; so you have quite a bit of work if you want to update it.ska wrote:Confirmed. I released a few frames earlier and managed 96.900 on 60-2 which can be seen in underclock mode. BTW, where's that "cheated runs inclusive" excel file with the absolute fastest score recorded for each level? I'd be interested to update that if someone can hook me up...
- Attachments
- HS 0ths.xlsx
- (60.91 KiB) Downloaded 261 times
I'm just curious like the rest of the community, of how close to 72k we are if legitimacy is not a restriction...
Yeah my MBD's should be updated.ska wrote:Thanks. Are all your MBD's current? That would be a great start if they are all current. If not, could you please update just those? Then, I'll update all the legit 0ths, underclock etc.
As for your other question the total level score is already 72163.075 without even updating the realtime column.
wow.. nice. thought that would be the case, but not that much!Raif wrote:Yeah my MBD's should be updated.ska wrote:Thanks. Are all your MBD's current? That would be a great start if they are all current. If not, could you please update just those? Then, I'll update all the legit 0ths, underclock etc.
I think it would be faster. The problem with the old route is that once you reach the drones at the top left they are in the wrong position to be able to get the exit switch quickly. Beating that drone on the right SHOULD let you nip in and out for the exit switch.vankusss wrote:THE question is, will it be faster? The best time i see on the boards using the old route, is 124.225, almost 2 seconds behind Izzy. Does beating the drone at top gain you 2 seconds?glib_jase wrote:60-4, variation of the "old" high scoring route:
On an unrelated note, has anyone got N working well on Windows 8 yet? I haven't spent much time on it but just switching to XP compatibility mode doesn't seem to help, it still lags like a biatch.
XP FTW!glib_jase wrote:I think it would be faster. The problem with the old route is that once you reach the drones at the top left they are in the wrong position to be able to get the exit switch quickly. Beating that drone on the right SHOULD let you nip in and out for the exit switch.vankusss wrote:THE question is, will it be faster? The best time i see on the boards using the old route, is 124.225, almost 2 seconds behind Izzy. Does beating the drone at top gain you 2 seconds?glib_jase wrote:60-4, variation of the "old" high scoring route:
Edit: And a more practical one for 181-4
Unreality's awesome mod
Edit: Just noticed people were posting about a thwump kick route for 60-2 above. What a weird coincidence.
Edit: Also this should be a little faster on 25-4 sr:
Another possibility would be this, although I doubt its doable:
Probably not enough lead (comparing with swips recent 0th). Im the ninja:
