in the spirit of Ninja warrior (the show on tv) I'm sure that means u have joint 0ths heh. But Swipenet made a big slip up on the jump through the middle crossing bit. That Homage map seems to have more similar gameplay than I expected, I guess its more 'critical' though.
It has to be said My remake is merely a continuation of Thrasher's design -I just followed the flow. So the credit goes nearly completely to T26 for the amazing look of it.
Btw I've listened to Oleary15 (you) about the gear map being too hard -and decided to get rid of that extra block gate on the exit and realized even more potential from the panels. Here's the result: http://www.thewayoftheninja.org/nv2.html?l=57258 Try & try Shortshifting
Map for you for sometime, thejumper741 www.thewayoftheninja.org/nv2.html?l=57241 No touching floor by Spartax18 (I think really cool, not sure if there are too tricky jumps later on, but I would've liked to beat it)
Nv2.0 User levels 0ths
Moderator: XandoToaster
- Cowboy Magician
I think that the jump in the middle crossing doesn't matter, currently I slow down at that point , the 0th is in the little final sprint, from the moment the drone leaves you pass, until the end, because before that point you have to wait for the drone you let go. (I tried to overcome the drone at the point where there is a button and a bit of gold on top. But it is very difficult)james_S wrote:in the spirit of Ninja warrior (the show on tv) I'm sure that means u have joint 0ths heh. But Swipenet made a big slip up on the jump through the middle crossing bit. That Homage map seems to have more similar gameplay than I expected, I guess its more 'critical' though.
In my run i can improve the last jump,in my previous race I was much faster here.
Now i try.james_S wrote: Map for you for sometime, thejumper741 http://www.thewayoftheninja.org/nv2.html?l=57241 No touching floor by Spartax18 (I think really cool, not sure if there are too tricky jumps later on, but I would've liked to beat it)
EDIT: For now, you can be satisfied with the speedrun mode ? 0th. :P
thecircus741: Drone-trainer
- Cowboy Magician
Jeeessus christ.. just realised that very hard jump you did to get up in the middle of the map, is just your short cut (not necessary to finish map). pretty cool :P
- Cowboy Magician
Quintal u signed up.. lol everyone wants to know where you're from :) (I mean how long u played n1.4 and stuff like that..)
- Cowboy Magician
http://n-game-v2.forumactif.org/
Btonios set up a new forum for N game -and it has an INSTANT CHAT feature (only shows when u log in though). I'm sure it'll be a success. Check out the new user levels thread on there: http://n-game-v2.forumactif.org/t3-nomi ... erlevels#5
too much forum/chat/levelswithmessage :D there is no people in this section of this forum.
