Rhino Cyanide Sandwich
Postby scythe » 2010.09.20 (20:22)
DemonzLunchBreak wrote:Laxatives in the rhino horn?
Nicotine. Cheap, and it'll make them vomit uncontrollably for a while.
Postby SlappyMcGee » 2010.09.20 (20:42)
I knew it! scythe is a Laramie Bot!
Postby Mute Monk » 2010.10.04 (15:24)
T̷s͢uk̕a͡t͜ư wrote:... we should start spreading rumors about the practitioners of Traditional Chinese Medicine, since they have the most access to the stuff, are using these libido-enhancing drugs all the time, and therefore the most potent drugs can actually be made out of their genitals.
I support this.
Maps
Postby squibbles » 2010.10.05 (00:47)
Having had a recent experiance, I'd just like to point out that this would still be rather dangerous. My housemates and I were smoking tobacco in large quantities from a hookah one night, and while I was fine, as I have some degree of a resistance to it being a smoker, two of the housemates was vomiting uncontrolably and did not appear to be in any danger, however one continued to do so with such violence that she tore her stomach lining and began vomiting blood. We spent the rest of that night in a hospital.
Postby scythe » 2010.10.05 (00:58)
For such a widely used substance, nicotine has a pretty tiny therapeutic ratio. It's lucky that smoking cigarettes is so inefficient, otherwise we'd see overdoses -- it's pretty much impossible to OD from cigarettes alone, as you'll start throwing up before you can smoke enough to die.
Nicotine is the only drug I've ever overdone it on. I had a lot of fun that night.
Postby Tanner » 2010.10.05 (02:14)
squibbles wrote:Having had a recent experiance, I'd just like to point out that this would still be rather dangerous. My housemates and I were smoking tobacco in large quantities from a hookah one night, and while I was fine, as I have some degree of a resistance to it being a smoker, two of the housemates was vomiting uncontrolably and did not appear to be in any danger, however one continued to do so with such violence that she tore her stomach lining and began vomiting blood. We spent the rest of that night in a hospital.
As a regular hookah user, I find this story scary. Perhaps fortunately, I've never smoked anything with nicotine in a hookah, it's always been either weed, tobacco-less shisha (essentially fruit and molasseses) or some combination thereof. Regardless, thanks for the warning.
Postby Kablizzy » 2011.06.03 (05:08)
steaveford wrote:Rhino Cyanide Sandwich should not affect how the rhino run their daily lives, such as going to the water hole, dipping their horns in, and thus poison the water. But I guess since it's inside the horn, it really will not matter.
...I can't for the fucking life of me tell if this is a bot or not.
