1.
2.
Here are 2 options if you wanted to use either one. let me know if you want any changes.
thank you :D
Theme Tilesets
Hey Jasdanu, If you need anything changed let me know, thanks :)
They're alright, but you should try to use all of the tiles to their maximum potential rather than resorting to what you're familiar with -- as in, try using different tile combinations to achieve similar results. It might work out better.
mapping since '06
-+- njitsu -+-
-+- njitsu -+-
Um okay....njitsu wrote:They're alright, but you should try to use all of the tiles to their maximum potential rather than resorting to what you're familiar with -- as in, try using different tile combinations to achieve similar results. It might work out better.
These are request based things, I do the best I can with what im given, If theres something that needs to be changed the person lets me know and then I fix it to what they like. So im not sure what else to do, if there were problems Im sure I would find out. I usually add a note after every one of the tilesets I do stating that If there are any problems to please let me know.
But I guess I say thank you for your advice, and ask maybe next time PM me with it.
Thanks.
I wasnt sure where you wanted the JD to go so i made them into like stalagtites coming from the ceiling.
If you wanted it different let me know. Thank you :)
Oh okay yeah I can do that, I wasnt sure how you wanted it done.
please bear with me I will have this up sometime soon. ive just started to go back to college and its hectic, I will get it up for you soon.
