N for ipod touch/iphone
MBTI Type: ESTP
Postby kkstrong » 2009.06.04 (00:57)
Or you could use seven_two's idea, then edit the tileset using your method...
Postby Tunco » 2009.06.04 (15:44)
kkstrong wrote:Or you could use seven_two's idea, then edit the tileset using your method...
But the logic behind what you said is not logically.
It would be just easier to use the method I said, or seven_two's idea.
Tunco123-talking about seven_two's idea wrote: It could be different the way you build the tilesets. There would be no automatic tilesets-1,2,3,4,5,6,7,8- you could just draw the tileset with your hand. But sure, automatic tileset option can be changed.
That's my idea about it.
