siiiiiiiiiiiiiiick. dronie-nom-worthy imo_danielr_ wrote:Nreality 81-4 sr (sorry/thanks again, jp)
The first chimney is a tad slow and I catch the thwump on the way back, but otherwise I'm very happy with it :)
Post a Run!
You're a god. Freaking insane run :D_danielr_ wrote:Nreality 81-4 sr
- Gross
- Gross
wow. nice innov - can be used for highscoring too by the look of it... (I'm talking to you, Eddy or macrohenry or perhaps a more weekender highscorer)MiBeM wrote:34-4 sr taken with a route change, probably my best run yet ^^ Still not quite perfect, I might try to squeeze off a few more frames later.
- Gross
It would be faster if you added a triple at the end (left side) like I do in my MBD. Also check my MBD for other improvements to the route. You can try the pj + bbbwj on the right side if you think you can do it :Dska wrote:wow. nice innov - can be used for highscoring too by the look of it... (I'm talking to you, Eddy or macrohenry or perhaps a more weekender highscorer)MiBeM wrote:34-4 sr taken with a route change, probably my best run yet ^^ Still not quite perfect, I might try to squeeze off a few more frames later.
Also me and TRO came up with the faster version of the route MiBeM uses nearly 3 years ago. You guys should really check my MBDs more often; there are atleast a few more routes that can be pulled off in realtime with a few changes.
I'll try that out, the right side in your run is far beyond my skill level though :DRaif wrote:It would be faster if you added a triple at the end (left side)
ahhh that's right! I knew I'd seen a faster route on that map!Raif wrote:It would be faster if you added a triple at the end (left side) like I do in my MBD. Also check my MBD for other improvements to the route. You can try the pj + bbbwj on the right side if you think you can do it :Dska wrote:wow. nice innov - can be used for highscoring too by the look of it... (I'm talking to you, Eddy or macrohenry or perhaps a more weekender highscorer)MiBeM wrote:34-4 sr taken with a route change, probably my best run yet ^^ Still not quite perfect, I might try to squeeze off a few more frames later.
On a somewhat related note, a couple of days ago I discovered that I can right click and select "show all", which makes the game area fill almost my whole monitor. That made my play a heck of a lot more consistent since I can see the game way better now. I don't know, this might be something everybody has been doing for years but I just found out and thought I'd share :D
I think a lot of highscorers/speedrunners are aware of this. (This only works in NReality though). I personally don't find it to affect my ability to play one way or the other, so just keep it the default size. Anyway.. nice run - I really think you could turn this into a highscores run if you have enough persistence...MiBeM wrote:Another 1,5 hours later I finally got under 1000 frames with the triple jump at the bottom left, thanks to Raif for suggesting that trick. This is definitely my favorite of all my runs so far.
I think I've had enough of that map for now...ska wrote:I really think you could turn this into a highscores run if you have enough persistence...
Also took 36-3, nothing fancy but it's a 0th which is always a big thing for me so I'll post it.
In the future, please denote which version of N and the mode you're using if applicable. i.e. N 1.4 36-3 sr. Nice run btw, but still 13 frames off the highscore 0th for the same level ;) Your speedrun would only be 4th on the 1.4 hs boards :DMiBeM wrote:I think I've had enough of that map for now...ska wrote:I really think you could turn this into a highscores run if you have enough persistence...
Oh, totally forgot, sorry about that. I'll be sure to mention it from now on :)ska wrote:In the future, please denote which version of N and the mode you're using if applicable.
Lol I wasn't boasting about it, I just pointed out I beat Msyjsm's run because that map is pretty famous among the community and that run had been very controversial back in its time, though you might not have heard about this since you are pretty new._danielr_ wrote:Wow jp, awesome run! Wasn't Eddy boasting about that not long ago? hahaha
Retaken anyway, and it can be pulled up to 13700 with some cleaning on the ws's and some other parts.
Well done on 45-0 jp, I thought I had maxed it. Tied it, I wonder if it has to do with rocket detection. When jumping earlier (trying to touch the corners) the rocket might detect you differently, hence making it possible to run a little more after taking the switch, before jumping, and gaining that frame. Just a shitty theory though.jp27ace wrote:Squeezed 1 more frame out of 45-0, I was trying to boost myself off the top corners but I couldn't get it to work
- Gross
Better than any theory I have :pEddyMataGallos wrote:Well done on 45-0 jp, I thought I had maxed it. Tied it, I wonder if it has to do with rocket detection. When jumping earlier (trying to touch the corners) the rocket might detect you differently, hence making it possible to run a little more after taking the switch, before jumping, and gaining that frame. Just a shitty theory though.jp27ace wrote:Squeezed 1 more frame out of 45-0, I was trying to boost myself off the top corners but I couldn't get it to work
Taken 99-1 with an innovation, also innovated 74-3 but couldn't quite beat votestraw, but I'm pretty sure its quicker
Edit: Took 74-3
Nice runs, taken ;)jp27ace wrote:Nice run Mibem, and yeah as ska said unless the drones somehow screw you over it looks like it could be used for high-scoring too.
Taken 60-3, 60-4, 61-2, and 64-1.
Nice runs I see you finally took 74-3. Retook 99-1. Interestingly I also thought on innovating 74-3, but never made a worthy change haha.jp27ace wrote:Taken 99-1 with an innovation, also innovated 74-3 but couldn't quite beat votestraw, but I'm pretty sure its quicker
- Gross
Sannnnnnnks
- Gross
Nice run van, I was going to try something like that at some point. Just wondering, is there a reason you don't do it on an earlier thwump?vankusss wrote:05-0 on v2.0
No. Taken a7-4 and b7-1ska wrote:don't wanna be a naggin nelly, but for fuck's sake, denote your goddam runs!
Also I'm now over 4.5m frames in v2.0
