A Day at the Office
Haha. That fire demon is so pissed.
Spontaneously become a ninja.
The guy at the door doesn't even look that angry. Just a little confused. Explain what you're doing so he doesn't feel out of the loop.
Quick, tell the fire demon to immolate the guy!
Jump off because the fire demon is burning your genitals.
Uh... put a big smile, grab the keys smoothly, climb down of the demon, pick the kit-kat and bribe the supposedly bad guy with it.
edit: oh, and this is plausible because that bad guy doesn't seem to have a gun, and you're the one with the keys.
Skyling wrote:Quick, tell the fire demon to immolate the guy!
What should I do?
Oh, get out of there and check what's outside. Don't forget your two partners. And the kit-kat.
Write "YANNI WUZ HERE" on the wall with the pencil, and then erase it when you see a guard coming by.
Donfuy wrote:Oh, get out of there and check what's outside. Don't forget your two partners. And the kit-kat.
What should I do?
- 20% Femme Fatale!
- NUMA Profile: http://nmaps.net/user/Clifty
Check to see if there's a label above the door of the room you're in.
kind of really inactive nowadays ;_;
N Fight - I SWEAR THAT I'LL DO NUMBER 5 SOME DAY
<Skyline> And in conclusion, Kwiftee is so outrageously hot that he puts the general public in risk of burning.
<3 Skyline- The Dreamster Teamster
- NUMA Profile: http://nmaps.net/user/sept
Attempt to escape and force any guards you encounter to engage you in double decker fights.
Kwiftee wrote:Check to see if there's a label above the door of the room you're in.
What should I do?
Kill the fire demon before he blows shit up.
- Oops Pow Surprise
Open Osama's Suite and tell him about the explosive stash. Then tell Obama, who will try to deter Osama from terrorizing things. While they are distracted, enter the third door.
Torex wrote:Kill the fire demon before he blows shit up.
What should I do?
Softly bite the skin of the explosives' scrotum.
Torex wrote:Softly bite the skin of the explosives' scrotum.
What should I do?
Look for an opening. If you find one, tell your red friend to burn it open.
Pikman wrote:Look for an opening. If you find one, tell your red friend to burn it open.
What should I do?
There's no time for air to the surface! Just go back and run into one of those suites (or the sweet). I'm sure one of them has to have a window you can escape from.
Skyling wrote:There's no time for air to the surface! Just go back and run into one of those suites (or the sweet). I'm sure one of them has to have a window you can escape from.
What should I do?
Call Jack Bauer.
Stealth kill the fire demon with your pencil, and then attempt to survive the blast by using his body as a shield.
sept wrote:Stealth kill the fire demon with your pencil, and then attempt to survive the blast by using his body as a shield.
"NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO"
WHAT SHOULD I DO.
