Tile help needed.
Postby beethoveN » 2009.09.23 (18:43)
I cannot get a good tileset for the life of me. at. all. as in, this is my best tileset (playable) Nmaps.net
but it is not that good. I need some help. could someone show me how to make a good tileset?
If we shadows have offended,
William Shakespeare
Postby ChaoStar » 2009.09.24 (00:29)
Huh. What I do: I make a shape. and then spam the shape all over the map. then make lines, via 3,2,7, and 6 tiles through everything. Then I mess around, and make things work.
Postby chume14 » 2009.09.24 (00:39)
I base my map around mechanisms or a particular mechanic think through the most complicated way in which it can all fit. I then build these mechanisms test them, modify them and radically change the layout of my map, test again, go get some coffee, test again and finally I start to think about tiles after that.
@Inspired that is quite a good method but there is a drastic change between steps 2 and 3 maybe you should go into more detail about precicely how you acheive that.
Postby njitsu » 2009.09.26 (18:08)
that's kinda how i do it.
mapping since '06
-+- njitsu -+-
Postby Tunco » 2009.09.26 (19:42)
Tunco123 wrote:I start off with building tiles. Where I build tiles is important, I like to focus on a single enemy, so as the tileset should provide the gameplay for it.
In this map, I will make the tileset to top of the map, and the focused enemy is on rockets.
First, I basically make a -not random- shape from E tiles.
Then, I place my ninja and some enemies.
I make tiles better.
I add gold to map and fix parts that is not good.
Adding mines and some more stuff that I see it's missing.
More changes and playtest.
Done!
How I make the tiles and the map are explained in this post. Well, I use Inspired's technique.
Postby MiBeM » 2009.10.01 (12:49)
I usually just think about some cool picture, and then start drawing it with the shapes of the tiles on paper. When that is done, I open my computer and start making the map.
a.k.a. MoleTrooper/Molenator
Speedruns and stuff
Users browsing this forum: Baidu [Spider], Google [Bot] and 35 guests
