Computer Problems
I was trying this thing, but I can't get it to do right. Help!! :o
Have you tried reversing the polarity of the secondary transfluxor array?
Take off your clothes. Blindfold yourself.
You know what you need?
Some Pan-Galactic Gargle Blaster.
Try holding down ctrl-shift-option-F6-4-8-*-home-s-k-Esc-RMB for exactly 7.4 seconds on the first tuesday after a full moon.
You'll need to aptget the telnet client and try to reflux the hosts folder. If that doesn't work, reboot your handlers and reflap.
I tried to do what you said but I might've done it wrong. The problem persists, albeit only partially.
Where did I mess up?
Sig'd.flagmyidol wrote:Take off your clothes. Blindfold yourself.
Also, towards which cardinal direction does your DVD drive open? Try pointing it towards Mecca.87654321 wrote:Hey, what are your computer specs? OS?
I think it's a Dell, but it could be a Mac.87654321 wrote:Hey, what are your computer specs? OS?Tsukatu wrote:I tried to do what you said but I might've done it wrong. The problem persists, albeit only partially.
I admit I smiled at that.rennaT wrote:Also, towards which cardinal direction does your DVD drive open? Try pointing it towards Mecca.87654321 wrote:Hey, what are your computer specs? OS?
Hahaha, that's quite clever.flagmyidol wrote:I admit I smiled at that.rennaT wrote:Also, towards which cardinal direction does your DVD drive open? Try pointing it towards Mecca.87654321 wrote:Hey, what are your computer specs? OS?
Also, your ambiguous multi-OS could easily be causing the problem. You may want to consider unplugging every single plug, then turning it into an amazingly large paperweight.
Get a Mac.
Install Linux to your Windows Vista/XP whatever.ortsz wrote:Get a Mac.
Have you tried formatting your motherboard?
If the keyboard can't connect, press F1 to continue.
I solved the problem.
Thanks!!
As this is probably a common problem, I'm going to sticky this so that people can link to it if someone comes by with the same issue.
Thanks!!
I told you to not use the phone with dial-up connected. :P
Silly Suki
Silly Suki
GLOBAL ANNOUNCEMENT'D!
- Walking on Broken Glass
what thing?
If we shadows have offended,
William Shakespeare
William Shakespeare
- RoboBarber
Make a little voodoo doll of your system32 folder, and poke it randomly until you find the corrupted data. Then cut out the affected area, burn it, and scatter the ashes onto your motherboard.
:loud music:
Smack your computer with a wrench.
And if that fails, use Glad Force Flex Bags. Crisis aversion guaranteed.
