The Melting Pot - A Public Collab: Map 13 Under Development
Postby Radium » 2009.09.20 (03:26)
UM FIX THE DRONE I FAILED
Postby Seneschal » 2009.09.20 (09:24)
Postby Pikman » 2009.09.21 (00:08)
Man, I wish we'd do this more often for Memoirs.
NOTE: One of the one-ways is broken.
Postby OneSevenNine » 2009.09.21 (03:15)
Some stuff.
:loud music:
Postby heatwave » 2009.09.21 (23:35)
heads up: that's cheatable.
Postby numa_ninja » 2009.09.22 (22:08)
Did anyone listen to Radium? Tsk, tsk, tsk.
Postby bufar » 2009.09.23 (00:20)
Still cheatable. I die at the end but you get the idea.
EDIT:
That's better.
Postby bobaganuesh_2 » 2009.09.28 (02:16)
I think this map proves why I don't do collabs. no offence Radium, but you managed to completely screw up the atmosphere of the map with your post.
Postby Radium » 2009.09.29 (02:50)
bobaga_fett wrote:I think this map proves why I don't do collabs. no offence Radium, but you managed to completely screw up the atmosphere of the map with your post.
Um. That still offended me greatly. These maps always turn out meh. Don't blame it all on me. I can map better than you, too.
Postby heatwave » 2009.09.29 (03:55)
Fuck atmosphere. This is a mapping experiment.
Postby Radium » 2009.09.29 (04:42)
Hells yes
NUMA Profile: http://nmaps.net/user/seven_two
Postby seven_two » 2009.09.29 (12:10)
Me thinks I should contribute to the map sooner or later, since I'm submitting it - how about you guys take your time making the map then I'll go tweak it when I'm free? Don't finish the map too soon, I reiterate. The map looks great. Thanks <3
Postby heatwave » 2009.10.05 (03:14)
Gosh, I can't think of anything to add. At this point, we'd usually post it, but seven_two still has things to add, huh?
Postby seven_two » 2009.10.12 (10:39)
Uh... yeah, but as of now I'm too busy for mapping.
Postby Aldaric » 2009.10.30 (03:30)
Can I start the next map?
Postby moonlight » 2009.10.31 (15:25)
I think seven_two forgot about this. :/
Postby seven_two » 2009.11.01 (06:48)
Go ahead and start the next map. If anything, someone else submit the map instead. ):
Postby Aldaric » 2009.11.01 (13:53)
I didn't really know how complete I was suppose to make it... Just threw some tiles around. Maybe someone will see something the can capitalize on.
Postby Yoshimo » 2009.11.08 (01:52)
Postby Aldaric » 2009.11.08 (02:30)
I think the tiles in the bottom half are not as good as the top. Can't think of something that would fit right now.
Postby seven_two » 2009.11.09 (11:15)
I murdered the map and just about everybody's contributions. I'm so sorry ;_;
All it needs is just a bit more polish. I'd appreciate it if someone would do it for me.
Postby Yoshimo » 2009.11.15 (03:52)
Aldaric wrote:I think the tiles in the bottom half are not as good as the top. Can't think of something that would fit right now.
Postby Slayr » 2009.11.15 (19:40)
I don't know if i have to join or anything but if not, here goes.
Postby heatwave » 2009.11.19 (01:52)
I think map 9 is fine as it is. What in particular do you think need polish?
Let's finish up Map 9:
And then continue with Map 10:
Postby Yoshimo » 2009.11.21 (01:16)
A bit extreme, and I can't help but add a teleport on every map.
