It's a skin with tons of bugs. Shouldn't be the default skin until Retronet is out. :/wedgie wrote:Just make chrome the default skin and dump the others. Then you don't have to worry about making the colours match more than one skin.
No name borders
When it's fixed it will probably default, but Retronet will probably be far superior so we'll probably end up using that instead.Tunco123 wrote:It's a skin with tons of bugs. Shouldn't be the default skin until Retronet is out. :/wedgie wrote:Just make chrome the default skin and dump the others. Then you don't have to worry about making the colours match more than one skin.
Or I'll make a Chrome v2.
Chrome v2? Why not make another skin instead making v2?Chase wrote:When it's fixed it will probably default, but Retronet will probably be far superior so we'll probably end up using that instead.Tunco123 wrote:It's a skin with tons of bugs. Shouldn't be the default skin until Retronet is out. :/wedgie wrote:Just make chrome the default skin and dump the others. Then you don't have to worry about making the colours match more than one skin.
-Retronet-
To be honest I'm quite happy with dumping Chrome all together once Retronet is finished.Tunco123 wrote:Chrome v2? Why not make another skin instead making v2?
-Retronet-
Because Robotology seems set for a 2011 release maybe?
I can fix that.SlappyMcGee wrote:I prefer Hermes, though. :/wedgie wrote:Just make chrome the default skin and dump the others. Then you don't have to worry about making the colours match more than one skin.
Bold. I like your style, boy.Wight wrote:I can fix that.SlappyMcGee wrote:I prefer Hermes, though. :/wedgie wrote:Just make chrome the default skin and dump the others. Then you don't have to worry about making the colours match more than one skin.
Incluye is the forum's Bob the Builder.Wight wrote:I can fix that.SlappyMcGee wrote:I prefer Hermes, though. :/wedgie wrote:Just make chrome the default skin and dump the others. Then you don't have to worry about making the colours match more than one skin.
user name problem solved. Go use Chrome. :)
EDIT: Half solved.
EDIT: Half solved.
- Demon Fisherman
If you cannot see any changes, press ctrl + F5. You'll need to refresh cookies. I had that problem, but fortunately knew how to fix it.
Users browsing this forum: Google [Bot] and 3 guests
