Whois?
- Steam: What's Steam
% This is the RIPE Database query service.
% The objects are in RPSL format.
% The RIPE Database is subject to Terms and Conditions.
% See http://www.ripe.net/db/support/db-terms-conditions.pdf
% Note: This output has been filtered.
% To receive output for a database update, use the "-B" flag.
% Information related to '89.241.0.0 - 89.243.255.255'
inetnum: 89.241.0.0 - 89.243.255.255
netname: OPAL-DSL
descr: Opal Telecom DSL
country: GB
admin-c: PM58-RIPE
admin-c: GD1052-RIPE
tech-c: PM58-RIPE
tech-c: GD1052-RIPE
status: ASSIGNED PA
mnt-by: OPAL-MNT
source: RIPE # Filtered
person: Phill Magill
address: Opal Telecommunications Plc
address: Northbank Industrial Estate
address: Irlam
address: Manchester
address: M44 5BL
address: United Kingdom
phone: +44 161 222-2000
fax-no: +44 161 222-2008
e-mail: [email protected]
nic-hdl: PM58-RIPE
mnt-by: OPAL-MNT
person: Gavin Ditchfield
address: Irlam
address: Manchester
address: M44 5BL
nic-hdl: GD1052-RIPE
mnt-by: OPAL-MNT
% Information related to '89.240.0.0/14AS13285'
route: 89.240.0.0/14
descr: Opal-Net Autonomous System
origin: AS13285
mnt-by: OPAL-MNT
% Information related to '89.242.0.0/15AS13285'
route: 89.242.0.0/15
origin: AS13285
mnt-by: OPAL-MNT
source: RIPE # FilteredOtherwise,
His YouTube video contains the text "whoistheenigmaiamtheenigma" and links to some Java encryption page.
I don't have sound on this machine, so I didn't hear any sound that might've played with the video.
Text from his only map ("11th") is from Luke 11:39, text specifically from the New International Version.
Text in map data: http://i970.photobucket.com/albums/ae18 ... tember.png
This image is reproduced below:
There is no slightly off-color text in the image. The background color is #CCCCCC, and the text color is #000000.
Hex dump for the file is nothing out of the ordinary for a PNG.
(For the record, these forums were created in / the Metanet Exodus happened in September 2008.)
Googling "A102938" gives, most notably, a number sequence, someone having issues with his PS3, "amber[looserface] !!", and this Asian fellow.
Without the "A", we have a spam page for "online school poker debt consolidation" and some loser who thinks he's a vampire.
Anyway, I'm thinking one of these keywords given is the decryption key (for that "JavaScypt" page) for some cypher I haven't found yet.
The encrypted text will either be groups of five capital letters beginning with "ZZZZZ", a series of valid hexadecimal characters (0-9, a-f) between "?HX?" and "?H", or a series of any sort of characters between "?b64" and "?64b".
Other crap:
If 102938 is actually 0x102938, it doesn't become anything meaningful when changed to decimal or octal. Neither does 0x0A102938 or 0xEA102938.
However, 102938 in hex is 0x1921a, which might be valuable information.
/noted.
No, Phill Magill is the network administrator to contact if you have questions about the ISP this EnigmA person uses.Flight wrote:So he's Phill Magill.
/noted.
If I'm right, I won't reveal it, unless I find his name the way he intended us to as well.
- Mr. Glass
Amiright?
Alphabetical. "+Who +is +the +Enigma"brighter wrote:
Amiright?
And Nreality refers to the image in the map that Tsukatu found. If you load the map in Nreality, that image is the background.Spawn of Yanni wrote:Alphabetical. "+Who +is +the +Enigma"
On another note, the map is named 11th, the image is http://i970.photobucket.com/albums/ae18 ... tember.png - i.e, called September, and the image displays the year 2008. That makes me think that we are looking at the date of the 11th September 2008?
THIS IS CLEARLY A TERRORIST THREAT EVERYONE IS BANNED FOR THEIR OWN SAFETYlord_day wrote:And Nreality refers to the image in the map that Tsukatu found. If you load the map in Nreality, that image is the background.Spawn of Yanni wrote:Alphabetical. "+Who +is +the +Enigma"
- Mr. Glass
Yeh, we know how tags don't work.Spawn of Yanni wrote:Alphabetical. "+Who +is +the +Enigma"brighter wrote:
Amiright?
T'was a joke. I'm hilarious. Etc...
He is Gavin Ditchfield.Tsukatu wrote:No, Phill Magill is the network administrator to contact if you have questions about the ISP this EnigmA person uses.Flight wrote:So he's Phill Magill.
/noted.
- Ego Lancer
Brilliant! Now, who is that?Tunco123 wrote:He is Gavin Ditchfield.Tsukatu wrote:No, Phill Magill is the network administrator to contact if you have questions about the ISP this EnigmA person uses.Flight wrote:So he's Phill Magill.
/noted.
Ooh, this is exciting, I've never been in a forum puzzle before.
Having said that, I only have a small thing to add. The numbers 102938 which are on the YT channel someone linked to above, when you take the number from the far left side, then far right side, then second from the left, then second from the right and so on. If you stop at 8, that's what you get. 102938. Don't know if that helps, actually.
Three members registered on the old forums on that date, though: toasters, subrama6, and BionicCryonic. I think he might be our man.
I'm still curious about the JavaScrypt thing, though.
Well, which one of them is British?Tsukatu wrote:These forums didn't have any members before September 18th, 2008.
None of them. :\EdoI wrote:Well, which one of them is British?Tsukatu wrote:These forums didn't have any members before September 18th, 2008.
Tsukatu wrote:I think I know the answer, but I got it using privileged information (and I doubt he intended his identity to be found the way I did).
Are you now trying to lead us on a false trail, were you wrong in your original guess, or are you giving us hints?Tsukatu (later) wrote:Three members registered on the old forums on that date, though: toasters, subrama6, and BionicCryonic. I think he might be our man.
Corresponding with the date the YouTube video was posted, there is an edit on the Wikipedia page "2008" by an unknown user, with a different IP than the one Suki posted. Not sure if this matters, but on April 26, it was edited to "The world will end" and all the entries afterward were deleted. Note that the listing for April 27 was:
Left the reference link in, in case it matters.April 27 – The Taliban attempts to assassinate Afghan President Hamid Karzai in a military parade in Kabul.[55]
- Radio Douchebag
Now playing: Calvin Harris - The Rain
via FoxyTunes
- Ego Lancer
Why not including yourself? :PUniversezero wrote:If join date is anything to go by, then this person could be one of 32 people, not counting myself.
via FoxyTunes
