Post a Run!
It's not a 0th, but I manage to get all six pieces of gold at the top AND pull off the corner jump to the left when all the other demos on the level only do one or the other but not both (unless I'm missing something). However, my route to do that is probably so simple and easy that it's a contender for the "Most Blatantly Obvious Innovation That Has Ever Been Missed" award.
Every time I drew only the one drone at the start of the vertical, the third (extra) one would be at the bottom right corner at the time when you and I get down there, blocking the route. With the other drone being on the left side as it is in my current demo, there was nowhere for me to go. If that doesn't make sense, I'll try and make a death demo in the next couple days for you.darkshadow wrote:Not quite sure which you mean but after drawing the drone at the start and making it up for the first vertical wall-jump the route is fairly simple so far as I remember. However I did get 0th first clean completion so I don't really know.golfkid wrote:Could be, but it'll have to wait at least a day, and probably more. But I guess I can give it a try. Did you get lucky with that third drone in the vertical shaft at the end, or were you able to consistently avoid it?
Edit: In my new 43-0 run if you're lucky you don't even need to wall jump on the way down on the left side which will save nearly 2 seconds (see my thread in troubleshooting).
Edit 2: Pulled it off but missed a gold (not too upset since it was a poor run anyways).
Edit 3: Did it another two times and missed a gold each time. Also, it seems to be closer to one second faster because the rocket gets in the way in the upper left.
Edit 4: Can anyone think of any levels besides 43-0 where this trick is useful?
Edit 5: I'm starting to be tempted to double post and I'm starting to hate 43-0. This is my fourth time screwing up:
Edit 6: Make that 6 times screwed up.
Unreality's awesome mod
and congrats on taking it by 2 seconds
- Doublemember
- NUMA Profile: http://nmaps.net/user/Viil
if ((nick = xaelar) || (nick = darkshadow)){
Continue.To.Another.Post;
else{
took 37-2 highscore from Lim by 7 frames with little innov (not sure if it's faster, though)
my first highscore metanet 0th ever
EDIT: hendor was using that innov before, noticed it now
return 0;
You forgot your #includes so I saw it. However I'm not going to have time to give it a shot most likely.vankusss wrote:int main(){
else{
return 0;
by nicnac
Application.OnKey "{RETURN}", "N"
End Sub
Public Sub N()
With ActiveSheet.Shapes.AddShape(msoShapeRectangle, _
800, 600, 0, 0)
.Name = "37-2"
.Fill.ForeColor.SchemeColor = 22
.Line.Visible = msoTrue
End With
With ActiveSheet.Shapes.AddShape(msoShapeNinjashape, _
5, 15, 40, 430)
.Name = "Ninja"
.Fill.Visible = msoTrue
.Line.ForeColor.SchemeColor = 14
.Fill.ForeColor.SchemeColor = 14
End With
ActiveSheet.Shapes("Ninja").GetAHighscore, "37-2"
ActiveSheet.Besttimes.AddBesttime(msoBesttimeHighscore, 198, .100, 37, -2).Name = "37-2"
ActiveSheet.Besttimes("37-2").Submit
End Sub
*presses RETURN* :D
(This is stupid VBA Stuff, meaning I have 198.100 in 37-2)
It could be only if you go to the lauchpad (you last touched before drone killed you) faster, maybe it's possible to avoid it.mohamedraif wrote:Do you think it's possible to avoid the drone?
edit: nevermind, xaelar found the map
by nicnac
- MBTI Type: ESFP
I think 158 or so will be max, with the route I used anyway.
- Doublemember
by nicnac
I can't work out if there is a quicker route that still avoids the rockets?
- Doublemember
Tied moh.Viil wrote:178819
