Postby Unreality » 2009.08.08 (02:10)
place it at the c:\
stupid flash won't recognize any non english character. You probably have placed it on a path where it contains non standard english characters.
for an example, I experienced the same problem when I placed NReality on chinese windows xp desktop, because the full path is
"C:\Documents and Settings\Unreality\桌面"
where 桌面 caused the nreality failed.
So please try placing it at c:\
Postby Nexx » 2009.08.08 (09:32)
Unreality wrote:So please try placing it at c:\
No change in behavior.
I keep thinking it must be missing a file or something, like how v6d4 requires the column files, but then I remember it was working fine on the previous machine with just as few files. :(
Postby Unreality » 2009.08.11 (12:16)
do you mind to capture a screenshot of all the files in your NReality6d4 folder?
Postby Nexx » 2009.08.12 (05:32)
I moved this discussion to its own thread because back and forth troubleshooting shouldn't be done in this main thread.
Postby 999_Springs » 2009.08.13 (20:42)
Unreality, could you please do something about all those practice mode scores in your NUMA database? It's quite annoying for those trying to get 0ths who realise that they can't because someone cheated on the level. I really want my star on NUMA map 1!
Commodus
Postby Rule » 2009.08.17 (14:55)
The main menu demo's are corrupted in my flash, and it doesn't save highcores...
And getting NUMA maps in by numbers desn't work either.
But these things must have been noticed before.
Postby Unreality » 2009.08.18 (13:34)
Rule wrote:The main menu demo's are corrupted in my flash, and it doesn't save highcores...
login your N and everything will be fine
Commodus
Postby Rule » 2009.08.19 (10:09)
Wow, I feel incredibly stupid now, thanks for the help on that. Now it works fine.
Postby sawyerscott52 » 2009.09.01 (15:03)
i downloaded the file, and i opened it. it worked the first time, then i closed it. when i tried to open it again, it showed a grey screen! it still had the white words in the margins, but the rest was blank!
why is this world so cruel?
death is, in and of itself, fascinating. sex... why deemed inappropriate? something that has always bugged me. shadows fall and the cities rise, sunlit moonrays take to the skies, this poem made no sense, all it did was rhyme. funny how people can be so... human... scary, more like. the people scare me. you never know what they'll say. i prefer criminals. at least you know when they'll shoot. "Once is Once"-L, Death Note Volume 5
Postby Tunco » 2009.09.01 (17:03)
sawyerscott52 wrote:i downloaded the file, and i opened it. it worked the first time, then i closed it. when i tried to open it again, it showed a grey screen! it still had the white words in the margins, but the rest was blank!
Just unpack the file. It'll work.
Postby Superpok » 2009.09.07 (06:04)
what are the *s next to highscores? what are the requirements for you to be eligible to get one on a level and stuff?
Signature Bars
MBTI Type: ESTP
Postby kkstrong » 2009.09.07 (08:47)
Superpok wrote:what are the *s next to highscores? what are the requirements for you to be eligible to get one on a level and stuff?
* means you have ro have had a 0th on the level or episode when 10 other people (at least) have submitted runs also.
Postby 999_Springs » 2009.09.07 (13:11)
* means you have to have had a 0th on the level or episode when 10 other people (at least) have submitted runs also.
It's just 9 other people, isn't it?
Postby Tunco » 2009.09.07 (13:57)
It's actually 10, by the fact that th numbers actually starts at 1 and 0 has a no value.
Yeah, it's 9. Though, I think people should have something like ** or *+ when they have 19 people behind them on the next version of NReality.
Postby vankusss » 2009.09.25 (10:47)
Unreality please check your PM's
Bacardi
NUMA Profile: http://nmaps.net/jinxed_07
Postby jinxed_07 » 2009.10.15 (14:35)
Me too, but i never had that problem last year when i had Nreality... odd
I sent Nreality to a few of my friends in one of my classes and now we are racing through the coloums..
Postby golf » 2009.12.07 (14:03)
Unreality,
I was looking through my scores on your infunity page, and noticed that my ep 30 score was marked as non-legit. I looked in NReality and saw that I had to retrieve that score from the tables for some reason, and it is labeled as v0 in my highscores. I know that I used v6d4 to make that run, since I did it this fall, and that's all I've used this year to play with. Could you change my score to being legit in your database?
Postby Unreality » 2009.12.07 (14:10)
golfkid wrote:Unreality,
fixed. The run in database does say it is v6d4
Postby amomentlikethis » 2009.12.07 (14:52)
Hi.
NUMA Profile: http://nmaps.net/user/n0_ma11y
Postby n0_ma11y » 2010.01.14 (00:24)
This allways shows up, on my pc it would load idk man btw Great program, check out some of my maps ;)
map pack ^
Postby golf » 2010.01.14 (01:00)
n0_ma11y wrote:This allways shows up, on my pc it would load idk man btw Great program, check out some of my maps ;)
Other than the highscores not loading, nothing seems wrong there. What usually loaded on your pc thats different from that pic?
Postby Raif » 2010.01.14 (19:23)
Is n.infunity.com blocked on your computer?
Postby Unreality » 2010.01.15 (07:46)
login and you will able to see the highscores
Postby Gregis » 2010.03.16 (04:26)
So what is NReality? Like a mod for N?
Sorry, I know if I read this thread I would know, it's just a bit wordy for me. What I did gander upon and absorb was that it has more levels. Does it have new bots? What else is new with it? Thanks! :D
Postby amomentlikethis » 2010.03.16 (14:41)
Gregis wrote:So what is NReality? Like a mod for N?
It's basically a mod of N. Lets you do more things, and highscores have better anti-cheat protection.
Hi.
